User:Bertrik Sikken
Revision as of 12:49, 1 December 2013 by Bertrik Sikken (talk | contribs)
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
  • software-defined radio
Project ideas:
  • do cool stuff with NRF24L01+ modules, e.g. connect one to the SPI bus of a Raspberry Pi
  • experiment with MQTT, a light-weight publish/subscribe framework for telemetry data
  • put the things above together in some kind of home automation project
  • build a colinear antenna out of RG-6 coaxial cable for the 70cm band (for receiving high-altitude balloons)
  • more radio stuff with the ham-it-up
  • implement dominoex/thor radio mode for a balloon payload, perhaps build a light-weight reusable library
  • come up with an algorithm to determine position/direction of bats as they pass a set of ultrasonic microphones
    • I've tried direct correlation, works but sometimes gives errors on bat calls with little frequency sweep
    • Planning to try correlation of only the amplitude data (derived with a Hilbert transform)
