HAB Tracker Station
Project HAB Tracker Station | |
Status | Completed |
Contact | User:Costyn_van_Dongen, Maxell, Bertrik_Sikken |
Last Update | 2013-09-28 |
Project page for the high altitude balloon tracking/listening station have set up in the space. This information is processed for the spacenear.us map
Overview
Done
- "ezcap USB 2.0 DVB-T/DAB/FM" dongle (RTL2838U, Fitipower FC0013 tuner)
- VK5QI HABamp
- Antenna: Diamond X-50N
- Windows XP, hostname "habtracker", IP 10.42.44.94 (MAC 00:21:70:02:62:0f)
- Start the machine with a magic WoL packet: 'wakeonlan -i 10.42.255.255 00:21:70:02:62:0f; ping habtracker'
- VNC: geheim ;-)
- Teamviewer ID: 675540724
Todo
- See if disconnect PC-ground from the antenna ground inproves noise figure
- Moar ferrite
- Metal box for some shielding (DIY or be lazy and get something like [1] or [2])
Pics
Derping around with hardware
One of the first decoding on dedicated machine tests
We are not using the Raspberry Pi anymore for rtl-tcp
The antenna: 'Diamond X-50N'
Deel 1
Coax will leave/enter the building trough the little chimney
The ideal antenna mounting spot; the old zonnecollector
Enclosure almost ready to rock
The magic pipe
Almost the same as having the Raspi on the roof
Power and network connected
Not sure what happened with the other hole there
The smell was't that bad
It pings!
The open pigtail even picks up our payload...
Deel 2
We took out the Raspberry Pi. We still use the enclosure for the rtl-sdr dongle and HABamp
Coax entering
oh hi
Look at the beautiful stainless steel bolts!
Oooooh!
The beauty
