UVBox
Revision as of 15:31, 5 June 2013 by Eddy Pronk (talk | contribs) (Project update June)
Project UVBox
Status in progress"in progress" is not in the list (Proposed, Initializing, In progress, Completed, Stalled, Abandoned) of allowed values for the "Project Status" property.
Contact user:Eddy Pronk
Last Update 2013-06-05
A cheap and simple UV exposure box for creating PCB's using the photoresist method. The current solution is huge and inconvenient.
The box will consist of a frame, a matrix of UV LEDs and a timer circuit. The solution will be geared towards 10x16cm copper clad boards, and will therefore have a small form factor. For the timer circuit I propose using one of my ATMEGA88's and an LCD module. The box will be powered by 12V and by putting LEDs in series (every 2 or 3 LEDs, depending on Vacross) I hope to keep wattage down.
500 UV LEDs are currently on a boat from China towards the space. This should be enough for at least 1 decent size box and a tanning bed.
Update June 2013: Almost finished soldering the boards. Each 10x16 prototype board contains 12 x 18 = 216 LEDs, and the enclosure will house 2 boards with 432 LEDs in total in a 20 x 16 configuration. For each 3 LEDs (in series) there is a single 68Ohm resistor. Total amperage per board is around 1.4A (observed).
