Karaburan
Project Karaburan
Monitoring water quality
Last Update 2024-10-15
  • write python scripts
    • arduino turbidity
    • turbidity-to-mqtt
  • hook things into systemd / udev
    • e.g. insert GPS -> create symlink with udev -> trigger (re)start of gpsd
Check:
USB HID as analog input
  • install openocd
 sudo apt install openocd
  • watch the kernel logs
 sudo dmesg -w
Verify that it works:
  • install the evtest package
  • run
influxdb
Topics:
  • air quality sensors
    • ammonia
    • NOx
  • water chemical analysis
    • nitrates
    • ammonia
    • dissolved oxygen
    • sulfide/sulfate
    • phosphates?
    • salinity (chlorides?)
  • water physical analysis
    • temperature
    • depth?
  • boat control
    • trajectory -> steering
  • camera control
  • post-processing
    • data presentation
      • video/photo stitching
      • time lapse view
      • map view of properties
  • use cases
    • minimum viable prototype
  • materials
    • boat selection
Investigate RTK GPS
  • stop gpsd.socket
  • run from command line
Validation
  • Relative positioning: with an "fix RTK" solution, place the antenna at 4 points 25cm apart, each point for 20 seconds or so -> you see 4 distinct clusters of points
  • Positioning over short time: put it in a fixed location, make sure that it has "fix RTK" solution, take 100 measurements or so -> determine the radius of the circle that contains 90% of the points
  • Positioning over longer time: do this for (say) an hour
  • Absolute positioning: look up a national reference point, for example "RD-punt 389346", located on the Sluisdijk between Gouda and Moordrecht. Technical data: https://www.nsgi.nl/iv-api/rdinfo/rdpoint/389346
Comparison with reference coordinate
On october 4th, we took the RTK GPS to a kernnet reference point at 51.99712236/4.68886324, results below:
  • For dy: 40075km/360 = 111,319 m/deg
  • For dx: dy * cos(latitude) = 68,549 m/deg
Measurements + deviations
Name Latitude Longitude dx (m) dy (m) absolute (m) Remark
Reference 51.99712236 4.68886324 - - 0 by definition
Screenshot 1 51.99712217 4.68886567 0.167 -0.021 0.168 -
Screenshot 2 51.99712200 4.68886533 0.143 -0.040 0.149 -
Meting 1 51.9971220 4.6888663 0.210 -0.040 0.214 -
Meting 2 51.9971222 4.6888660 0.189 -0.018 0.190 -
Average - - 0.177 -0.030 0.180 -
Air quality sensors
Nitrogen compounds in air
  • NOx: 27.3 ug/m3
  • NO2: 18.6 ug/m3 (9.9 ppb)
Water physical analysis
Turbidity / clarity
Boat control
  • 2.4 GHz working frequency
  • 500m range
Interesting links:
remote control
Parts:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
Detect/find pollution source
Implementation
reading temperature sensor
Preparation:
 sudo adduser <name> dialout
Setting up the hardware:
Setting up the software:
  • Install openwire fs
 sudo apt install owfs
 sudo mkdir /mnt/1wire
 server: device = /dev/ttyUSB0
 mountpoint = /mnt/1wire
 allow_other
  • Configure systemd services
 sudo systemctl disable owftpd
  • Start the systemd service
  • Check the logs
 http://localhost:2121 or
 http://raspberrypi.local:2121
