Karaburan
Project Karaburan | |
Monitoring water quality | |
Contact | bertrik |
Last Update | 2024-07-17 |
- write python scripts
- arduino turbidity
- turbidity-to-mqtt
- e.g. insert GPS -> create symlink with udev -> trigger (re)start of gpsd
- analoog in op de pi:
- 1-wire stuff:
USB HID as analog input
- install openocd
sudo apt install openocd
- watch the kernel logs
sudo dmesg -w
Verify that it works:
- install the evtest package
- run
influxdb
investigate RTK GPS
- Chipsets
- Quectel LC29H, see https://rtklibexplorer.wordpress.com/2024/04/28/dual-frequency-rtk-for-less-than-60-with-the-quectel-lc29hea/
- uBLOX ZED-F9P
- Boards
- UM980 / UM982
- Tau1202 is dual-band, but not RTK
- GT-U13 is dual-band, but not RTK
- stop gpsd.socket
- run from command line
Topics:
- air quality sensors
- ammonia
- NOx
- water chemical analysis
- nitrates
- ammonia
- dissolved oxygen
- sulfide/sulfate
- phosphates?
- salinity (chlorides?)
- water physical analysis
- temperature
- depth?
- boat control
- trajectory -> steering
- camera control
- post-processing
- data presentation
- video/photo stitching
- time lapse view
- map view of properties
- data presentation
- use cases
- minimum viable prototype
- materials
- boat selection
Air quality sensors
Nitrogen compounds in air
- NOx: 27.3 ug/m3
- NO2: 18.6 ug/m3 (9.9 ppb)
Water physical analysis
Turbidity / clarity
Boat control
- 2.4 GHz working frequency
- 500m range
Interesting links:
remote control
Parts:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
Detect/find pollution source
Implementation
reading temperature sensor
Preparation:
sudo adduser <name> dialout
Setting up the hardware:
Setting up the software:
- Install openwire fs
sudo apt install owfs
sudo mkdir /mnt/1wire
- Configure systemd services
- Start the systemd service
- Check the logs
