Karaburan
Project Karaburan
Monitoring water quality
Status Initializing
Last Update 2024-06-23
  • write python scripts
    • gpsd-to-mqtt
    • arduino turbidity
    • turbidity-to-mqtt
  • hook things into systemd
investigate RTK GPS
Goal: figure out if it is practically possible to achieve cm resolution with a 200-euro GPS and a free correction service
 GPSD_OPTIONS="ntrip://user:pass@ntrip.kadaster.nl:2101/CBW100NLD0"
Topics:
  • air quality sensors
    • ammonia
    • NOx
  • water chemical analysis
    • nitrates
    • ammonia
    • dissolved oxygen
    • sulfide/sulfate
    • phosphates?
    • salinity (chlorides?)
  • water physical analysis
    • temperature
    • depth?
  • boat control
    • trajectory -> steering
  • camera control
  • post-processing
    • data presentation
      • video/photo stitching
      • time lapse view
      • map view of properties
  • use cases
    • minimum viable prototype
  • materials
    • boat selection
Air quality sensors
Nitrogen compounds in air
  • NOx: 27.3 ug/m3
  • NO2: 18.6 ug/m3 (9.9 ppb)
Water physical analysis
Turbidity / clarity
Boat control
  • 2.4 GHz working frequency
  • 500m range
Interesting links:
remote control
Parts:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
Detect/find pollution source
Implementation
reading temperature sensor
Preparation:
 sudo adduser <name> dialout
Setting up the hardware:
Setting up the software:
  • Install openwire fs
 sudo apt install owfs
 sudo mkdir /mnt/1wire
 server: device = /dev/ttyUSB0
 mountpoint = /mnt/1wire
 allow_other
  • Configure systemd services
 sudo systemctl disable owftpd
  • Start the systemd service
  • Check the logs
 http://localhost:2121 or
 http://raspberrypi.local:2121
