EspAudioSensor
Project ESP audio sensor
ESP32-based audio sensor
Last Update 2023-06-28
From TheThingsNetwork, the data is picked up by a kind of 'integration' that sends it to sensor.community. This is handled by my sensor-data-bridge noise forwarder Java project.
RIVM noise measuring project:
I would like to build a case like that!
Github links to the project of Marcel Meek / TTN Apeldoorn:
Links back:
TODO
  • figure out which LoRaSoundkit is "current" (most up-to-date) -> this one: https://github.com/meekm/LoRaSoundkit
  • figure out alternative pinning for LoRaSoundkit so it works for both TTGO and Heltec boards
  • put it together!
Sound meter projects
Ideas
Bluetooth interface
The ESP32 supports bluetooth as an RF technology. It would be nice to be able to quickly see the current/most recently measured data. This can be shown on the display. Perhaps even more convenient, this can be exposed over bluetooth for display on a mobile phone. Are there android apps that can interface with bluetooth?
The Bluetooth specification reserves 0x27C3 as the measurement unit code for sound pressure (dB) and 0x2BE4 as the noise characteristic.
How the BLE indicate and notify work, and the difference between them: https://openlabpro.com/guide/ble-notify-on-esp32-controller/
The characteristic 'noise' is not one of the characteristics permitted for the 'environmental sensing service', see https://bitbucket.org/bluetooth-SIG/public/src/main/assigned_numbers/profiles_and_services/ess/ess_permitted_characteristics.yaml so this probably has to be specified in a custom service
The concept is the following:
  • A small box containing a microphone outside your house measures environmental sounds (traffic, etc), for example it takes a 1 second audio recording every 10 seconds
  • A spectral analysis is made of the audio (separating it in different frequency bands), calculating sound intensity for each individual band
  • Every 5 minutes, the measured sound intensity is sent to a central server on the internet. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
  • The central server takes the measured intensities and can do corrections, like a microphone specific correction, or a correction to apply A-weighting
  • The central server forwards the measurements to sensor.community, from there they are automatically picked up by RIVM
Theory
A weighting
Octave start Octave center Octave end Remark
- - 22627 Hz sample rate
5657 Hz 8000 Hz 11314 Hz
2828 Hz 4000 Hz 5657 Hz
1414 Hz 2000 Hz 2828 Hz
707 Hz 1000 Hz 1414 Hz
354 Hz 500 Hz 707 Hz
177 Hz 250 Hz 354 Hz
88 Hz 125 Hz 177 Hz
44 Hz 63 Hz 88 Hz
22 Hz 31 Hz 44 Hz
FFT
  • arduinoFFT does all calculations in double, severely limiting the audio buffer size. For each sample, you need two doubles, so that's 16 bytes per sample. I can use about 6000 samples in the audio buffer. Using floats gives me twice the audio buffer size.
  • Alternatively, esp32-fft looks nice, it uses floats instead of doubles and is optimised for esp32, but it uses malloc internally ... Also I can't use it as an Arduino library because it doesn't have the arduino library structure (with a src dir, examples dir, library.json file, library.properties file, etc) Maybe I can still use it by copying it in my sketch.
Links:
Decibel meters
Fairly typical specs:
  • dynamic range: 30 - 130 dB
  • accuracy: 1.5-2 dB
  • frequency range: 31.5 Hz - 8 kHz (!)
  • norm: EN 61672-1
  • an ESP32, it has an I2S digital audio input for sampling data from a digital microphone and a WiFi interface to communicate things to the internet. It has more internal RAM than an ESP8266 (for example), this helps to take a larger audio sample and do analysis on it. It is still comparatively simple, cheap, easy to flash and powerful enough to do communication over WiFi and do audio analysis.
  • a digital I2S microphone, like the INMP441 (datasheet)
Ideally, we come up with a pinout that allows both the TTGO and Heltect boards to be used with essentially the same firmware.
NodeMCU ESP32
  • INMP441 GND to ESP32 GND
  • INMP441 VDD to ESP32 3.3V
  • INMP441 SD to ESP32 A4/32
  • INMP441 SCK to ESP32 A16/14
  • INMP441 WS to ESP32 15
  • INMP441 L/R to ESP32 GND
Heltec LoRa32 v2
Preliminary, for the LoRaSoundKit:
ESP32 INMP441 Remark
GND GND -
3.3V VDD -
35 SD conflicts with LoRa DIO1!
14 (A16) SCK -
15 WS -
GND L/R -
Microphones
  • INMP441: cheap microphone
  • SPH0645: untested
  • ICS-43434: expensive, used in the DNMS can apparently be found more cheaply now, for like $3
Casing
Casing prototype
My own initial attempt: lasdoor + wartel + 5/8 inch pvc pipe on the right.
Original experimental code
  • Take an audio measurement from a digital microphone at a regular interval.
  • On the recorded audio, perform a 4096-point real->complex FFT with a windowing function (flat-top).
  • Calculate power for each FFT-bin (Im-squared + Re-squared) and sum up bins per octave.
  • Display as a kind of ASCII-art 'waterfall'.
Citizen science code
firmware
backend code
I have written a forwarder application in Java that takes the data from that sensor from TheThingsNetwork and forwards it to sensor.community: https://github.com/bertrik/noiseforwarder -> is now integrated in my sensor-data-bridge.
Improvement ideas
To improve on the sound sensor of Marcel Meek, I intend to change the following:
  • Minor fixes on the build system:
    • make sure it compiles without a link error caused by duplicate hal_init() function
    • fix minor compiler errors, like "warning: no return statement in function returning non-void [-Wreturn-type]"
  • Make it work on a Heltec LoRa32 v2 board
    • This could be just adding a platformio configuration
    • Might also require remapping of the pins, since pin 35 (IIS data in) is already used for LoRa DIO1 on the Heltec LoRa32 v2
  • Avoid burn-in of the OLED display
    • Currently the OLED continuously shows the most recent measurement data, the OLED is known to suffer from burn-in, making the display unreadable after a couple of months
    • The plan is to add a timeout, e.g. turn off display after 2 minutes, reactivate by button-press
  • Add firmware update interface
    • Internal webpage over WiFi that allows you to select a bin file and update the firmware over-the-air
  • Add easier commissioning of LoRaWAN parameters
    • Currently the node shows credentials using very small characters
    • Nice solution would be to make this machine-readable, like a QR code on the display with TTN credentials as long as it has not successfully joined TTN
  • Allow local reading of the most currently measured noise value
    • Add a bluetooth BLE GATT interface with the most recently measured dBa value
    • Maybe a sensor.community-style web page data.json file?
DNMS
  • the module produces a single value with a minimum and a maximum value (not a spectrum), no spectral corrections are possible
  • the communication interface is I2C, where the sound sensor is I2C slave, which is more difficult to implement than (for example) a 9600 bps serial interface
  • the communication protocol is a bit weird, e.g. sends an 8-bit CRC for every 16-bit data word
  • it needs a custom PCB
  • building the firmware is unnecessary complex
DNMS Protocol:
  • as reverse engineered from the sensor.community firmware:
    • device is at i2c address 0x55 (7-bit or 8-bit address?)
    • commands exchanged are 16-bit
      • 1 DNMS_CMD_RESET
      • 2 DNMS_CMD_READ_VERSION
      • 3 DNMS_CMD_CALCULATE_LEQ
      • 4 DNMS_CMD_READ_DATA_READY
      • 5 DNMS_CMD_READ_LEQ
    • a command looks like this:
      • 16-bit (big endian) command id
      • a variable number of 16-bit data words, each with an 8-bit CRC
    • getting the data from the DNMS:
      • send the DNMS_CMD_CALCULATE_LEQ command
      • repeat DNMS_CMD_READ_DATA_READY command until it indicates that a measurement is available
      • send the DNMS_CMD_READ_LEQ command, this results in three values: a, a_min and a_max
      • if an error occurred, send the DNMS_CMD_RESET command
Sensor.community protocol
  • REST with JSON
  • HTTP POST request to "https://api.sensor.community" with path "/v1/push-sensor-data/"
  • the POST contains the following HTTP headers:
    • HTTP header "X-Sensor" contains the unique hardware id, for an ESP32-board, an id of type "esp32-<number>" would be appropriate
    • HTTP header "X-Pin" with value 15
    • HTTP header "Content-type" with value "application/json"
  • the POST body contains the following fields:
    • "software_version", description of the software version
    • "sensordatavalues", list of structures:
      • "value_type" = "noise_LAeq", "value" = value in dB
      • "value_type" = "noise_LA_min", "value" = value in dB
      • "value_type" = "noise_LA_max", "value" = value in dB
Links:
