MainsFrequency2.0
Project MainsFrequency2.0 | |
A simple mains frequency counter | |
Contact | bertrik |
Last Update | 2023-03-16 |
Concept
Desired end result
- get more accurate frequency measurement
- get more responsive frequency measurement, i.e. instantaneous value, not a running average over 50 seconds.
Algorithm for getting accurate instantaneous frequency out of it:
- Sample the mains frequency waveform during approximately one second (say 5 - 10 kHz)
- Determine the median, lower and upper quartiles of the waveform, and shift data so its values are symmetrically around zero
- Calculate zero crossings by doing linear regression to find the zero-crossing of the wave in the region around the zero crossing (in between the quartile values), this gives sub-sample time resolution
- The linear regression runs a kind of state machine, just keeping track of sum(x), sum(y), sum(x*x), sum(x*y) is enough to perform a linear regression at any time
- Do this over the approximately 50 cycles contained in the one second data and determine average frequency
ZMPT101B | Wemos D1 mini | Remark |
GND | GND | Ground |
VCC? | 5V | Power |
pin? | A0 | Analog mains waveform, 0..5V |
