Msi2500SDR
Revision as of 07:18, 10 August 2022 by Bertrik Sikken (talk | contribs) (Created page with "{{Project |Name=Msi2500SDR |Picture=Msi2500SDR.jpg |Omschrijving=Making an inexpensive MSI2500 software-defined-radio work on Linux |Status=In progress |Contact=bertrik }...")
Project Msi2500SDR
Last Update 2022-08-10
This page is about an inexpensive SDR with MSI2500/MS101 chip, basically a chinese clone of the SDRPlay RSP1. It is in some places also referred to as BG7YZF.
On this page, I'm documenting how to get it to work effectively under Linux.
This device has the following properties:
  • 5 separate SMA input for 5 different frequency bands
  • USB-C interface to computer (USB high speed?)
  • Samples radio at up to 8 MHz (?) and 12-bits
  • Has a stable and accurate oscillator (TCXO), compared to (for example) the rtl-sdr
Linux
This thing seems to be semi-supported by Linux:
  • there are msi2500 and msi101 kernel drivers, generally it seems you should not use them
  • supported by "soapysdr"
  • supported by "gr-osmo"
  • supported a "libmiri"
The thing that worked best for me, is the libmiri package by f4exb, together with SDR software sdrangel (also by f4exb)
Linux kernel driver
It appears that SDR is not usable with the Linux kernel driver installed.
To uninstall it (and avoid automatically loading it), do the following:
  • remove the modules manually
sudo modprobe -r msi2500 msi001
sudo modprobe
  • create a file /etc/modprobe.d/blacklist-msi.conf
  • contents should be
blacklist msi001
blacklist msi2500
libmiri + sdrangel
For me (bertrik), using Debian (bookworm/sid) the following gives a usable SDR setup to play with:
Build and install libmiri by f4exb:
git clone https://github.com/f4exb/libmirisdr-4
cd libmirisdr-4
mkdir build && cd build
cmake ..
nice make -j3
sudo make install
Build sdrangel by f4exb:
  • install at least the following development packages (sudo apt install ...)
qtbase5-dev
qtbase5-private-dev
qtlocation5-dev
qtmultimedia5-dev
qtpositioning5-dev
qtwebengine5-dev
libqt5charts5-dev
libqt5serialport5-dev
libqt5texttospeech5-dev
libqt5websockets5-dev
 git clone https://github.com/f4exb/sdrangel.git
  • build it
 cd sdrangel
 mkdir build
 cd build
 cmake ..
 make -j3
