VINDRIKTNING
| Project VINDRIKTNING | |
| Hacking IKEA VINDRIKTNING PM2.5 indicator | |
| Last Update | 2022-03-06 |
What
- power is by USB-C 5V
- the particulate matter sensor is the PM1006, probably very similar to the Cubic PM1006K but with a slightly different command set
- has LEDs for three colours (red, orange and green)
- has a light level sensor
- the sensor output can be PWM or UART, the UART output provides a PM2.5 value
- there is a footprint for a kind of debug header, with signals ISPDA, RESET, ISPCLK, GND, +5V
- there is an internal header with signals LED_G_1, PWM_Fan, LED_R_1, FAN-, FAN+
- there is a separate header for the fan with signals FAN+,FAN-
- there is an 8-pin IC, could this be the "main" microcontroller?
- there is a light-sensing element, that controls the brightness of the LED
More pictures of its internals, with reverse-engineered schematics: https://threadreaderapp.com/thread/1415291684569632768.html
VINDRIKTNING Schematic by Adam Hořčica
NOTE: the schematic appears to swap pin 2 and 4 which connect the GND and +5V!!!
Interfacing with ESP8266
The datasheet of the PM1006 mentions that it takes 5V as power and communicates using 4.5V levels. The reverse-engineered schematic shows resistors in line with the RX and TX lines. An ESP8266 should be 5V tolerant. This means that it is probably possible to directly connect an ESP8266 in place of the original microcontroller.
The series resistors limits the current from the PM1006 TX line into the ESP8266 RX line.
Hacking
The microcontroller is an ES7P001.
Idea: Fit an ESP8266 that reads out the raw PM value and publish it over WiFi, e.g. using a home assistant compatible protocol.
With no PM1006 attached at all, the sensor indicates "green", or good air quality!
What I've done:
- Remove the existing microcontroller entirely
- Solder wires to the internal test pads and attach a Wemos D1 mini, the serial line resistors currently in place can be of use to limit 5V/3.3V interface issues.
Pinout:
- Wemos D1 mini D2 -> PM1006 RX = "ISPDA" pad
- Wemos D1 mini D1 -> PM1006 TX = "RESET" pad
- Wemos D1 mini A0 -> VINDRIKTNING LDR = "LED_R1" pad
- Wemos D1 mini D0 -> VINDRIKTNING FAN control = "PWM_FAN" pad
- Wemos D1 mini D5 -> VINDRIKTNING green LED = LED_G1" pad
- Wemos D1 mini D3 -> VINDRIKTNING red/orange LED = "ISPCLK" pad
Unfortunately, the ESP8266 output voltage is not enough to light the orange LED. It can only control the red LEDs and the green LEDs.
Protocol
Mentioned here, the MCU sends
11 02 0B 01 E1
This is different from the command mentioned in the PM1006K data sheet!
Command:
- 1 byte: 0x11
- 1 byte: length N of command data
- N bytes:command data
- 1 byte: check sum
Response:
- 1 byte: 0x16
- 1 byte: length N of response data
- N bytes: response data
- 1 byte: check sum
The first byte of the command data is the command code. The first byte of the response data echoes back the same command code.
Someone told me:
- The PM1006K "PM" command results in the same PM2.5 value as the PM1006 "PM2.5" command, the PM1.0 and PM10 values will be 0 in the response
Experimentation
Using the 'c' command in the .ino file, you can experiment with different commands: It appears that at least the following commands return data:
- [0x01] undocumented?
- [0x02] command mentioned in the PM1006K datasheet, returns array of PM-values, but only PM2.5 is filled
- [0x0B 0x01] command mentioned in the PM1003 datasheet, used in the original firmware
For example:
>m Measuring... PM2.5 = 33 OK >c 01 CMD: 01 RSP: 01 00 00 03 A7 00 00 03 AA 00 00 00 22 OK
Obviously the 0x22 in the end is the PM2.5 concentration (34 ug/m3). But what about the other numbers, 0x3A7 and 0x3AA?
>c 02 CMD: 02 RSP: 02 00 00 00 22 00 00 00 00 00 00 00 00 OK
This command just returns the PM2.5 (0x22 = 34 ug/m3)
>c 0b01 CMD: 0B 01 RSP: 0B 00 00 00 22 00 00 03 A7 00 00 00 2D 02 00 00 0C OK
Again the PM2.5, again the 0x3A7 number that is also present in the 01 response. What about the 2D and 02 and 0C bytes?
Perhaps the 0x2D number is a kind of estimate for PM10, it seems to be correlated to PM2.5, but always higher in value. The 0x0C value is always the same.
I wonder if perhaps this thing also has a "secret" temperature sensor that can be read. The datasheet (PM1006_LED_PARTICLE_SENSOR_MODULE_SPECIFICATIONS.pdf) mentions: "Integrated temperature sensor, temperature compensation within the whole temperature range"
Code for an ESP8266 (Wemos D1 mini) to communicate with the PM1006 sensor inside this device can be found at https://github.com/bertrik/pm1006
