LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2021-12-19
What is it?
The concept consists of:
  • a sensor that measures airborne particulate matter and sends the measurement data using LoRaWAN to TheThingsNetwork (TTN)
  • a forwarder application that collects the data from TTN and forwards it to sensor.community (formerly luftdaten), opensensemap, mycayenne dashboard, etc.
Features
  • Supported particulate matter sensors (auto-detected):
    • Nova Fitness SDS011 particulate matter sensor, provides PM10, PM2.5
    • Sensirion SPS30 particulate matter sensor, provides PM10, PM4.0, PM2.5, PM1.0
    • BME280 humidity/temperature/pressure sensor, provides humidity, temperature, barometric pressure
  • Uses LoRaWAN/TheThingsNetwork for communicating the measurement values:
  • Hardware is based on off-the-shelf ESP32+LoRa hardware, specifically
    • TTGO LoRa32 v1 and
    • Heltec LoRa32 v2
  • Works with TTNv3, the most recent version of TheThingsNetwork infrastructure
  • Uses over-the-air-activation (OTAA), parameters have a sensible default and are stored in EEPROM:
    • Device EUI defaults to the ESP32 built-in unique id
    • APP EUI and APP key can be configured using the serial port
  • LoRaWAN OTAA credentials are shown as a QR-code so they are machine-readable
  • Uses LoRaWAN automatic-data-rate (ADR) to optimise data rate and transmit power
  • Data upload interval defaults to 5 minutes (SF7), scales with spreading-factor to satisfy the fair-access-policy of TheThingsNetwork
  • Data is encoded over LoRaWAN as Cayenne LPP, no custom payload decoder needed
  • Supports WiFi over-the-air firmware upgrade
Similar nodes
  • Automate building and uploading of BIN files on github with github actions/workflows
  • Restructure firmware a bit to make the main .ino file smaller
  • Implement a simple command set through LoRaWAN downlink commands, for example:
    • create a basic command structure: command port, payload encoding, e.g. 1st byte is command id
    • a command to trigger an immediate reboot of the node
    • a command to assist in geolocation, performing a WiFi AP scan:
      • Per AP we send 8 bytes: 1) MAC 2) RSSI 3) channel, so a total of 6 APs can be send in 48 bytes
Ideas:
  • Base send interval on the exact time spent sending data, investigate if the LoRaWAN device stack supports this -> not currently explicitly supported
  • Add support for Davis Airlink local API, more information at https://weatherlink.github.io/airlink-local-api/
  • Make measurement values available through bluetooth
  • Implement the ESP-Now lamp/display protocol, for easy visualisation, see https://revspace.nl/StofAnanas#Next_generation.
    • Start with sending the particulate matter measurements
    • Add a suggested colour indication later
QR code for TheThingsNetwork credentials
LoRaWAN credentials
  • QR contents will be:
    • DevEUI based on ESP32 unique id
    • AppEUI (fixed in the firmware)
    • AppKey to be randomly generated (and stored in EEPROM), much more secure than a fixed key
  • QR code library: https://github.com/ricmoo/QRCode
  • Example content should fit in 29x29 pixel version 3 QR code (format "OTAA:JoinEUI:DevEUI:AppKey" as hexadecimal)
OTAA:1122334455667788:1122334455667788:112233445566778899AABBCCDDEEFF00
The node is based on Arduino-compatible ESP32 boards with LoRaWAN:
  • For the processor board, either the
    • TTGO ESP32 board ("ttgo-lora32-v1") or the
    • Heltec LoRa32 V2 can be used.
  • The particulate matter sensor is the SDS011 or the SPS30, the sensor type is auto-detected.
  • The humidity/temperature sensor is the BME280 (superior to the DHT11/22).
Pinout
TTGO LoRa v1 Heltec LoRa v2 Sensor Remark
5V 5V 5V (SDS pin 3) SPS30 5v (red), triple-check this, swapping 5V/GND destroys the SDS011
GND GND GND (SDS pin 5) SPS30 gnd (black), triple-check this, swapping 5V/GND destroys the SDS011
GPIO23 GPIO23 RXD (SDS pin 6) SPS30 RX (white?)
GPIO22 GPIO22 TXD (SDS pin 7) SPS30 TX (purple?)
3.3V 3.3V/Vext BME280 3V Both Vext and 3.3V can be used
GND GND BME280 GND ground
GPIO15 GPIO15 BME280 SCL Piggybacking on the I2C bus to the display
GPIO4 GPIO4 BME280 SDA Piggybacking on the I2C bus to the display
For reference:
Display
The display on the ESP32 LoRa boards is an 128x64 pixel OLED display. It wears out after some months, pixels that have been on more than other pixels will become dimmer.
Hackaday article about this effect. The burn-in/dimming effect is very obvious here.
The firmware tries to auto-detect an external display, and if found, disable the internal display to avoid burn-in.
Things to keep in mind when connecting an external display:
  • You need a 128x64 display with I2C interface (not SPI), four pins VDD/GND/SCL/SDA
  • Choose either a full yellow or full cyan OLED. OLEDs with *white* pixels seem to burn in quite quickly. Avoid picking a partial yellow/partial cyan OLED, the QR code with LoRaWAN OTAA credentials cannot be displayed correctly on these.
  • The pin order appears to vary, in particular take note of VDD and GND, they can be exactly the other way around between models
Firmware
  • install platformio:
 sudo apt install python3-pip
 sudo pip3 install platformio
 pio update
  • get the source from github:
  • enter the correct directory:
 cd LoraWanPmSensor
  • compile and upload (for TTGO LoRa32 v1 board):
 pio run -e ttgov1 -t upload
 pio run -e heltecv2 -t upload
  • when source code has updated, run the following and perform the previous step again after that
 git pull
Firmware update
Firmware update
Once the initial firmware has been loaded into the device, further firmware updates can be done over WiFi:
  • Depending on the board you have, check that you have either a ttgov1.bin or heltecv2.bin firmware file
  • Connect to the access point set up by the node, it's called 'ESP-XXXXXXXXXXXX', where XX is the same as the LoRaWAN device EUI
  • Using a browser, go to http://192.168.4.1 , a firmware selection screen appears as shown on the right
  • Select the appropriate BIN file, the firmware will be updated and the board reboots
Payload encoding
Cayenne
  • 4 bytes: PM10: analog input (type 2), channel id 1, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • 4 bytes: PM2.5: analog input (type 2), channel id 2, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • 4 bytes: Temperature: temperature (type 103), with value in units of 0.1 degrees celcius
  • 3 bytes: Humidity: humidity (type 104), with value in units of 0.5 %
Optionally:
  • 4 bytes: PM1.0: analog input (type 2), channel id 0, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • 4 bytes: Pressure: barometer (type 115), with value in units of 0.1 mbar, or 10 Pa (optional)
Example:
Binary
LoraWan time budget
Consider the following:
  • radio regulations generally have a 1% duty cycle requirement for the two bands used by the 8 LoRaWAN (EU) frequencies, so according to the legal limits, there is about (86400s x 1% x 2bands) = 1728 seconds per day send time at the best case.
  • TheThingsNetwork has a FUP of 30s of data upload per day. This is actually a *lot* more strict than allowed purely by radio regulations.
  • The sensor.community backend runs on a 5 minute interval, or 288 measurements per day.
  • The default sensor.community WiFi firmware sends new data every 145s by default
In terms of interval:
  • SF7: payload 17 bytes -> 71.9 ms/transmission -> every 3m27s
  • SF8: payload 17 bytes -> 123,4 ms/transmission -> every 5m55s
  • SF9: payload 17 bytes -> 226,3 ms/transmission -> every 10m32s
  • SF10: payload 17 bytes -> 452.6 ms/transmission -> every 21m43s
  • smallest possible binary payload is 4 bytes (PM10 and PM2.5, no temperature, no humidity): SF7 takes 51.5 ms, SF8 takes 92.7 ms, SF9 takes 164.9 ms
  • smallest Cayenne payload is 8 bytes (PM10 and PM2.5, no temperature, no humidity): SF7 takes 56.6 ms, SF8 takes 102.9 ms, SF9 takes 185.3 ms
Downlink commands
I plan the following downlink commands:
  • "info", retrieves information on the platform, hardware and firmware version
  • "reboot", performs a remote reboot, OTAA will be performed. This command should only be sent UNconfirmed, as the reboot is performed *before* sending the reply back. This could result in a reboot-loop. A reboot request with confirmed bit is therefore ignored.
  • "locate", performs a wifi scan so the node can be located, response data contains an 8-byte structure per AP: 6-byte MAC address, 1-byte RSSI, 1-byte channel. A max of 6 APs is reported.
Principles:
  • command requests are sent over a specific port, say port 100
  • responses are sent back on the same port
  • commands can be confirmed or unconfirmed, the response will mimic the command in this respect
  • commands and responses have a simple structure: first byte is command id, rest is command/response-specific
