LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2021-07-26
What is it?
The concept consists of:
  • a sensor that measures airborne particulate matter and sends the measurement data using LoRaWAN to TheThingsNetwork (TTN)
  • a forwarder application that collects the data from TTN and forwards it to sensor.community (formerly luftdaten), opensensemap, mycayenne dashboard, etc.
Features
  • LoRaWAN-enabled particulate matter sensor node, based on off-the-shelf ESP32+LoRa hardware, specifically the TTGO LoRa32 v1 and Heltec LoRa32 v2 board.
  • Works with the most recent version (v3) of TheThingsNetwork infrastructure
  • Uses over-the-air-activation (OTAA), parameters have a sensible default and are stored in EEPROM:
    • Device EUI defaults to the ESP32 built-in unique id
    • APP EUI and APP key can be configured using the serial port
  • Uses LoRaWAN automatic-data-rate (ADR) to optimise data rate and transmit power
  • Data upload interval defaults to 5 minutes (SF7), scales with spreading-factor to satisfy the fair-use-policy of TheThingsNetwork
  • Data is encoded as Cayenne LPP, no custom payload decoder needed
  • Supported sensors (auto-detected):
    • Nova Fitness SDS011 particulate matter sensor, provides PM10, PM2.5
    • Sensirion SPS30 particulate matter sensor, provides PM10, PM4.0, PM2.5, PM1.0
    • BME280 humidity/temperature/pressure sensor, provides humidity, temperature, barometric pressure
  • Firmware can be upgraded over-the-air (WiFi)
Similar nodes
  • Base send interval on the exact time spent sending data, investigate if the LoRaWAN device stack supports this -> not currently explicitly supported
  • Implement a simple command set through LoRaWAN downlink commands, for example:
    • a command to trigger an immediate reboot of the node
    • a command to assist in geolocation, performing a WiFi AP scan:
      • Per AP we send 8 bytes: 1) MAC 2) RSSI 3) channel, so a total of 6 APs can be send in 48 bytes
    • create a basic command structure: command port, payload encoding, e.g. 1st byte is command id
  • Implement the ESP-Now lamp/display protocol, for easy visualisation, see https://revspace.nl/StofAnanas#Next_generation.
    • Start with sending the particulate matter measurements
    • Add a suggested colour indication later
  • Improve firmware update:
    • Show current software version in the welcome screen
    • Show hardware model (TTGO or Heltec) in the welcome screen
  • Add support for Davis Airlink local API, more information at https://weatherlink.github.io/airlink-local-api/
QR code for TheThingsNetwork credentials
QR code with credentials
  • Show QR code on startup containing DevEUI, AppEUI and AppKey, for easier commissioning
    • DevEUI based on ESP32 unique id
    • AppEUI could be fixed
    • AppKey could be randomly generated (and stored in EEPROM), much more secure than a fixed key
    • QR code library: https://github.com/ricmoo/QRCode
    • Example content should fit in 29x29 pixel version 3 QR code (format "DevEUI:AppEUI:AppKey" as hexadecimal)
1122334455667788:1122334455667788:112233445566778899AABBCCDDEEFF00
The node is based on Arduino-compatible ESP32 boards with LoRaWAN:
  • For the processor board, either the
    • TTGO ESP32 board ("ttgo-lora32-v1") or the
    • Heltec LoRa32 V2 can be used.
  • The particulate matter sensor is the SDS011 or the SPS30, the sensor type is auto-detected.
  • The humidity/temperature sensor is the BME280 (superior to the DHT11/22).
Pinout
TTGO LoRa v1 Heltec LoRa v2 Sensor Remark
5V 5V 5V (SDS pin 3) SPS30 5v (red), triple-check this, swapping 5V/GND destroys the SDS011
GND GND GND (SDS pin 5) SPS30 gnd (black), triple-check this, swapping 5V/GND destroys the SDS011
GPIO23 GPIO23 RXD (SDS pin 6) SPS30 RX (white?)
GPIO22 GPIO22 TXD (SDS pin 7) SPS30 TX (purple?)
3.3V 3.3V/Vext BME280 3V Both Vext and 3.3V can be used
GND GND BME280 GND ground
GPIO15 GPIO15 BME280 SCL
GPIO4 GPIO4 BME280 SDA
For reference:
Firmware
  • install platformio:
 sudo apt install python3-pip
 sudo pip3 install platformio
 pio update
  • get the source from github:
  • enter the correct directory:
 cd LoraWanPmSensor
 cd Esp32PmSensor
  • compile and upload (for TTGO LoRa32 v1 board):
 pio run -e ttgov1 -t upload
 pio run -e heltecv2 -t upload
Firmware update
Firmware update
Once the initial firmware has been loaded into the device, further firmware updates can be done over WiFi:
  • Depending on the board you have, check that you have either a ttgov1.bin or heltecv2.bin firmware file
  • Connect to the access point set up by the node, it's called 'ESP-XXXXXXXXXXXX', where XX is the same as the LoRaWAN device EUI
  • Using a browser, go to http://192.168.4.1 , a firmware selection screen appears as shown on the right
  • Select the appropriate BIN file, the will be updated and reboot
Payload encoding
Cayenne
  • 4 bytes: PM10: analog input (type 2), channel id 1, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • 4 bytes: PM2.5: analog input (type 2), channel id 2, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • 4 bytes: Temperature: temperature (type 103), with value in units of 0.1 degrees celcius
  • 3 bytes: Humidity: humidity (type 104), with value in units of 0.5 %
Optionally:
  • 4 bytes: PM1.0: analog input (type 2), channel id 0, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • 4 bytes: Pressure: barometer (type 115), with value in units of 0.1 mbar, or 10 Pa (optional)
Example:
Binary
LoraWan time budget
Consider the following:
  • radio regulations generally have a 1% duty cycle requirement for the two bands used by the 8 LoRaWAN (EU) frequencies, so according to the legal limits, there is about (86400s x 1% x 2bands) = 1728 seconds per day send time at the best case.
  • TheThingsNetwork has a FUP of 30s of data upload per day. This is actually a *lot* more strict than allowed purely by radio regulations.
  • The sensor.community backend runs on a 5 minute interval, or 288 measurements per day.
  • The default sensor.community WiFi firmware sends new data every 145s by default
In terms of interval:
  • SF7: payload 17 bytes -> 71.9 ms/transmission -> every 3m27s
  • SF8: payload 17 bytes -> 123,4 ms/transmission -> every 5m55s
  • SF9: payload 17 bytes -> 226,3 ms/transmission -> every 10m32s
  • SF10: payload 17 bytes -> 452.6 ms/transmission -> every 21m43s
  • smallest possible binary payload is 4 bytes (PM10 and PM2.5, no temperature, no humidity): SF7 takes 51.5 ms, SF8 takes 92.7 ms, SF9 takes 164.9 ms
  • smallest Cayenne payload is 8 bytes (PM10 and PM2.5, no temperature, no humidity): SF7 takes 56.6 ms, SF8 takes 102.9 ms, SF9 takes 185.3 ms
Downlink commands
I plan the following downlink commands:
  • "info", retrieves information on the platform, hardware and firmware version
  • "reboot", performs a remote reboot, OTAA will be performed. This command should only be sent UNconfirmed, as the reboot is performed *before* sending the reply back. This could result in a reboot-loop. A reboot request with confirmed bit is therefore ignored.
  • "locate", performs a wifi scan so the node can be located, response data contains an 8-byte structure per AP: 6-byte MAC address, 1-byte RSSI, 1-byte channel. A max of 6 APs is reported.
Principles:
  • command requests are sent over a specific port, say port 100
  • responses are sent back on the same port
  • commands can be confirmed or unconfirmed, the response will mimic the command in this respect
  • commands and responses have a simple structure: first byte is command id, rest is command/response-specific
