EspAudioSensor
Project ESP audio sensor | |
ESP32-based audio sensor | |
Contact | bertrik |
Last Update | 2021-07-10 |
The plan is to do this by combining an inexpensive WiFi-enabled ESP-32 microcontroller with a standard I2S digital microphone. The ESP-32 performs a frequency analysis and is able to forward the measurement to a server.
Further development:
- It seems to work so far! Let's test it, e.g. by running it all day and plotting the noise values.
- Add a feature to forward the audio directly, so we can verify the received audio actually makes sense, is not excessively loud (e.g. clipping) or soft.
- Add client code for uploading data somewhere, perhaps just start with sending MQTT into influx, so we can plot things using grafana
How can you help
How you can help with this project:
- help me find an answer to the following questions:
- what are the norms for audio measurement? how often? how long?
- help me qualify the microphone currently chosen
- help me design a nice case for the project, also taking some practical things into account
- weather protection
- providing power
- help me with the server infrastructure
- help me making this project more widely known
- I probably cannot help *you* with your political mission to stop/ban certain noisy activities that annoy you. My main motivation is technical, I just like to measure things and visualise them.
The concept is the following:
- Every 5 minutes, the measured sound intensity is sent to a central server on the internet using your home WiFi connection. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
- The central server visualises the measurements:
- We can plot the sound intensities on a map as a coloured dot and get a nice overview how the map changes during the day/week/year
- We can plot the sound intensities of individual nodes vs time, and get an idea how sound varies from day/night/week/year
- how often should audio be sampled? 1 second/minute? 10 seconds/min?
Theory
The plan is to divide the audio spectrum up into octaves and calculate the total energy in each octave. We can then easily apply sensor/housing specific corrections, do A weighting, etc.
A weighting
Octave start | Octave center | Octave end | Remark |
- | - | 22627 Hz | sample rate |
5657 Hz | 8000 Hz | 11314 Hz | |
2828 Hz | 4000 Hz | 5657 Hz | |
1414 Hz | 2000 Hz | 2828 Hz | |
707 Hz | 1000 Hz | 1414 Hz | |
354 Hz | 500 Hz | 707 Hz | |
177 Hz | 250 Hz | 354 Hz | |
88 Hz | 125 Hz | 177 Hz | |
44 Hz | 63 Hz | 88 Hz | |
22 Hz | 31 Hz | 44 Hz |
FFT
- arduinoFFT looks nice, but .. it does all calculations in double, severely limiting the audio buffer size. For each sample, you need two doubles, so that's 16 bytes per sample. I can use about 6000 samples in the audio buffer. Using floats would give me twice the audio buffer size. I could just copy the files and modify them for double->float (and fix any other compiler warnings).
Links:
Decibel meters
Fairly typical specs:
- dynamic range: 30 - 130 dB
- accuracy: 1.5-2 dB
- norm: EN 61672-1
The microphone is connected to the microcontroller as follows:
- INMP441 GND to ESP32 GND
- INMP441 VDD to ESP32 3.3V
- INMP441 SD to ESP32 A4/32
- INMP441 SCK to ESP32 A16/14
- INMP441 WS to ESP32 15
- INMP441 L/R to ESP32 GND
What the software should do:
- Take an audio measurement from the microphone at a regular interval (say 1 second every 10 seconds)
- On the recorded audio, perform a 4096-point real->complex FFT with a windowing function (flat-top for example).
- Calculate statistics, e.g. minimum/average/maximum over a 5 minute interval and convert to a logarithmic scale (decibels)
- Every 5 minutes, send the statistics to the network using WiFi or LoRa
DNMS
- it needs a custom PCB
- the module produces only a single value with a minimum and a maximum value (not a spectrum)
- it is probably more expensive than needed
- the communication protocol is a bit weird, sends an 8-bit CRC for every 16-bit data word
It would be nice to be compatible with this sensor, so an ESP32 audio sensor can be a drop-in replacement for the "official" DNMS module.
This sound sensor basically consists of a custom PCB, with a Teensy as a processor. It has an I2C slave interface that is read by the main ESP8266 of the sensor.community node.
Protocol:
- is there a clear description of the protocol?
- reverse engineered from the sensor.community firmware:
- 1 DNMS_CMD_RESET
- 2 DNMS_CMD_READ_VERSION
- 3 DNMS_CMD_CALCULATE_LEQ
- 4 DNMS_CMD_READ_DATA_READY
- 5 DNMS_CMD_READ_LEQ
- a command looks like this:
- send the "calculate LEQ" command
- wait until "read data ready" command indicates that a measurement is available
- send the "read LEQ" command, this results in three values: a, a_min and a_max
- if an error occurred, send the 'reset' command
Links:
