LoraWanDustSensor
| Last Update | 2021-01-08 |
The concept
The concept consists of:
This has been done before by other people, but it appears there is no universal solution. I am publishing all source code on github and will put up documentation on this wiki. This concept uses Cayenne because it is the closest practical thing towards a universal format but still reasonably compact format.
- Apeldoorn-in-data
- (others...)
The OTAA key is hardcoded into the node, the session keys are not. The node identifies itself by its built-in unique ESP32 serial number.
- each node can be flashed with the same firmware
- the node shows its unique Device EUI on the OLED
- at the TTN console, you register the node with the unique Device EUI
- the sensor node receives encryption keys over the air automatically by OTAA
- Implement the ESP-Now lamp/display protocol, for easy visualisation, see https://revspace.nl/StofAnanas#Next_generation. This sends both the measured values (to show on a display) plus a color to indicate how 'bad' the situation is (to show on an RGB LED)
- Start the LoRaWAN OTAA procedure at a slower rate than SF7, so it doesn't take a long time before the node finally connects to the network if it's not close to a gateway
- Firmware update over WiFi:
- basic OTA-over-WiFi has been implemented, allows remote flashing from the development environment, not so user-friendly, not secure
- basic OTA-over-WiFi with a timeout, not so user-friendly, not very secure
- next step is to use the ESP32 as access point + web server, user-friendly (only a browser needed to upload firmware images), not very secure
- final step is to use the ESP32 as access point + web server, using signed images, this is user-friendly and secure
The node is based on the Arduino framework:
- for the processor board, either the TTGO ESP32 board ("ttgo-lora32-v1") or the Heltec LoRa32 V2 can be used.
- the particulate matter sensor is the SDS011, just like in the sensor.community project.
- the humidity/temperature sensor is the BME280 (superior to the DHT11/22).
Pinout
| 5V | 5V | SDS011 5V (pin 3) | triple-check this, swapping 5V/GND destroys the SDS011 |
| GND | GND | SDS011 GND (pin 5) | triple-check this, swapping 5V/GND destroys the SDS011 |
| GPIO23 | GPIO23 | SDS011 RXD (pin 6) | |
| GPIO22 | GPIO22 | SDS011 TXD (pin 7) | |
| GPIO15 | GPIO15 | BME280 SCL | |
| GPIO4 | GPIO4 | BME280 SDA |
For reference:
- install platformio:
- get the source from github:
cd LoraWanPmSensor cd Esp32PmSensor
pio run -e ttgov1 -t upload
pio run -e heltecv2 -t upload
On Windows, with the Arduino IDE
- Install the Arduino IDE ...
- Get the ESP32 support package ...
- Install the following libraries
- squix78/ESP8266_SSD1306
- mcci-catena/MCCI LoRaWAN LMIC library, version 3.3.0
- sparkfun/SparkFun BME280
- Set the target to either the TTGO LoRa32 v1 or Heltec LoRa32 v2
- Ctrl-U to compile and upload
Payload encoding
My firmware uses the Cayenne LPP (low power payload) encoding.
Cayenne
- 4 bytes: PM10: digital input (type 2), channel id 1, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
- 4 bytes: PM2.5: digital input (type 2), channel id 2, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
Optionally:
- 4 bytes: PM1.0: digital input (type 2), channel id 0, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
Example:
Binary
- 1 byte : 0x04
- 2 bytes: PM25(?) big endian
- 2 bytes: PM10(?) big endian
- RIVM node, sends 20 bytes
- 2 bytes pressure (unit?)
- 2 bytes pm10 (unit?)
- 2 bytes pm25 (unit?)
- 2 bytes op1 (unit?)
- 2 bytes op2 (unit?)
- 4 bytes latitude (unit?)
- 4 bytes longitude (unit?)
LoraWan time budget
Consider the following:
In terms of interval:
Node design
The luftdaten backend has a 5 minute "heartbeat", so at least one measurement per 5 minutes should be sent to avoid disappearing from the map. The node firmware (attempts to) send a message every 4m30s seconds, just like the luftdaten WiFi sensor. A little bit of randomness (30 s) is added to avoid nodes transmitting at exactly the same time over long periods of time and interfering with each other.
- INIT: determine presence of the SDS011, print the SDS011 serial number
- IDLE: wait until the start of the cycle, then turn on the fan
- WARMUP: wait 20 seconds while the sensor "warms up"
- MEASURE: measure 10 seconds, then turn off fan, calculate median/average and send LoRaWAN message
Building with platformio
To compile and upload:
TTN key provisioning
To keep things simple, there is no key provisioning for the nodes themselves. All nodes use the same firmware with the same APP EUI and the same APP KEY. The thing that makes each node unique is its DEVEUI, this is derived from the built-in unique ESP32 id.
On the TTN side, each node will have to be registered by its DEV EUI. The following scheme is used to make TTN provisioning as simple as possible:
- Each node can be programmed with the *same* software, no source code modification is required
- The node administrator needs to enter the following properties at the TTN console, for each node:
- The Device EUI is derived from the node-specific ESP32 MAC address, the node shows this on its OLED
- The App EUI has a fixed value and is the same for all nodes
- The App Key has a fixed value and is the same for all nodes
- Use 32-bit frame counter, leave frame counter checks enabled
The node uses a fixed App EUI and App key by default, but each node can also be configured to use a custom set of OTAA keys.
Backend
- subscribe to a TTN MQTT stream and receive incoming messages
- decode Cayenne and custom payloads
- forward to luftdaten.info/sensor.community
- forward to opensensemap.org
- forward to feinstaub app (experimental), https://pm.mrgames-server.de/
Development
To receive data using mosquitto, separately from the backend:
Example upstream data:
Example downstream data:
Gateway API:
Useful tools:
- packet decoder: https://lorawan-packet-decoder-0ta6puiniaut.runkit.sh/
- airtime calculator: ...
