EspAudioSensor
Project ESP audio sensor | |
ESP32-based audio sensor | |
Contact | bertrik |
Last Update | 2019-09-17 |
The plan is to do this by combining an inexpensive WiFi-enabled ESP-32 microcontroller with a standard I2S digital microphone. The ESP-32 performs a frequency analysis and is able to forward the measurement to a server.
Further development:
- It seems to work so far! Let's test it, e.g. by running it all day and plotting the noise values.
- Apply A-weighting locally to get a direct idea of the loudness
- Add client code for uploading data somewhere, perhaps just start with sending MQTT into influx, so we can plot things using grafana
Another idea:
- implement basic speech recognition of fixed phrases, like "ok google", "hey siri", AKA "wake words"
The concept is the following:
- Every 5 minutes, the measured sound intensity is sent to a central server on the internet using your home WiFi connection. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
- The central server visualises the measurements:
- We can plot the sound intensities on a map as a coloured dot and get a nice overview how the map changes during the day/week/year
- We can plot the sound intensities of individual nodes vs time, and get an idea how sound varies from day/night/week/year
Theory
The plan is to divide the audio spectrum up into octaves and calculate the total energy in each octave. We can then easily apply sensor/housing specific corrections, do A weighting, etc.
A weighting
Octave start | Octave center | Octave end | Remark |
- | - | 22627 Hz | sample rate |
5657 Hz | 8000 Hz | 11314 Hz | |
2828 Hz | 4000 Hz | 5657 Hz | |
1414 Hz | 2000 Hz | 2828 Hz | |
707 Hz | 1000 Hz | 1414 Hz | |
354 Hz | 500 Hz | 707 Hz | |
177 Hz | 250 Hz | 354 Hz | |
88 Hz | 125 Hz | 177 Hz | |
44 Hz | 63 Hz | 88 Hz | |
22 Hz | 31 Hz | 44 Hz |
FFT
- arduinoFFT looks nice, but .. it does all calculations in double, severely limiting the audio buffer size. For each sample, you need two doubles, so that's 16 bytes per sample. I can use about 6000 samples in the audio buffer. Using floats would give me twice the audio buffer size. I could just copy the files and modify them for double->float (and fix any other compiler warnings).
Links:
Decibel meters
Fairly typical specs:
- dynamic range: 30 - 130 dB
- accuracy: 1.5-2 dB
- norm: EN 61672-1
- an ESP32 (or possibly an ESP8266), it has an I2S digital audio input for sampling data from a digital microphone and a WiFi interface to communicate things to the internet
The microphone is connected to the microcontroller as follows:
- INMP441 GND to ESP32 GND
- INMP441 VDD to ESP32 3.3V
- INMP441 SD to ESP32 A4/32
- INMP441 SCK to ESP32 A16/14
- INMP441 WS to ESP32 15
- INMP441 L/R to ESP32 GND
What the software should do:
- Take an audio measurement from the microphone at a regular interval (say 1 second every 10 seconds)
- On the recorded audio, perform a 4096-point real->complex FFT with a windowing function (flat-top for example).
- Calculate statistics, e.g. minimum/average/maximum over a 5 minute interval and convert to a logarithmic scale (decibels)
- Every 5 minutes, send the statistics to the network using WiFi or LoRa
