EspAudioSensor
Project ESP audio sensor
ESP-based audio sensor
Status Initializing
Last Update 2019-04-16
The plan is to do this by combining an inexpensive WiFi-enabled ESP-32 microcontroller with a standard I2S digital microphone.
The idea is the following:
  • A small box containing a microphone outside your house measures environmental sounds (traffic, etc), for example it takes a 1 second audio recording every 10 seconds
  • A spectral analysis is made of the audio (separating it in different frequency bands), calculating sound intensity for each individual band
  • Every 5 minutes, the measured sound intensity is sent to a central server on the internet using your home WiFi connection. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
  • The central server takes the measured intensities and can do corrections, like a microphone specific correction, or a correction to apply A-weighting
  • The central server visualises the measurements:
    • We can plot the sound intensities on a map as a coloured dot and get a nice overview how the map changes during the day/week/year
    • We can plot the sound intensities of individual nodes vs time, and get an idea how sound varies from day/night/week/year
Theory
The plan is to divide the audio spectrum up into octaves and calculate the total energy in each octave. We can then easily apply sensor/housing specific corrections, do A weighting, etc.
Subjective audio levels are generally calculated on a logarithmic scale in dB using "A-weighting". A-weighting calculates a subjective loudness level from a physical loudness, applying a correction factor for each band. The division of the audio spectrum is chosen so it matches the octaves used in the A-weighting, see https://en.wikipedia.org/wiki/Octave_band#Octave_Bands
FFT
The energy in each octave is calculated by applying an FFT (fast fourier transform) on the audio data. The FFT takes in real values and outputs complex values. The intensity in each octave band is by summing the energy in a set of FFT 'bins'. The energy in each bin is calculated as the real part squared plus the imaginary part squared.
Links:
Decibel meters
Fairly typical specs:
  • dynamic range: 30 - 130 dB
  • accuracy: 1.5-2 dB
  • frequency range: 31.5 Hz - 8 kHz (!)
  • norm: EN 61672-1
  • an ESP32 (or possibly an ESP8266), it has an I2S digital audio input for sampling data from a digital microphone and a WiFi interface to communicate things to the internet
  • a digital I2S microphone, like the INMP441 (datasheet)
Waag society uses the following microphone in their kit 2.1: Invensense ICS4342. I ordered these INMP441 microphones from Aliexpress.
The microphone is connected to the microcontroller as follows:
  • INMP441 GND to ESP32 GND
  • INMP441 VDD to ESP32 3.3V
  • INMP441 SD to ESP32 A4/32
  • INMP441 SCK to ESP32 A16/14
  • INMP441 WS to ESP32 15
  • INMP441 L/R to ESP32 GND
The clock signal is 64 times higher than the sample clock, so at a sample rate of 44100 Hz, this means 2.8 MHz. This might be a bit high for a random wire, probably we should keep this connection short.
Initial code can be found on github.
What the software should do:
  • Take audio measurement from the microphone at a regular interval (say 1 second every 10 seconds)
  • On the recorded audio, perform a 4096-point FFT with a windowing function (Gaussian for example). This results in 2048 FFT coefficients.
  • Sum up FFT into power per octave, e.g. top 1024 coefficients represent octave of 11025-22050 Hz, next 512 coefficients represent is 5512-11025 Hz octave, etc.
  • Calculate statistics, e.g. minimum/average/maximum as decibels in the current 5 minute interval
  • Every 5 minutes, send the statistics to the network using WiFi
To investigate:
