EspNowSkip
Project EspNowSkip
350px
Music skip button based on ESP-Now protocol
Status Initializing
Contact bertrik, jelly
Last Update 2018-05-06
  • you want it to react reasonably quickly, with little latency between pressing the button and skipping to the next song
  • the skip button should be mobile, so it is battery powered and has to conserve power
The ESP-Now protocol is connectionless, you don't need to set up a session/get an ip-address to communicate between nodes.
The hardware is based on ESP8266, they are cheap and ubiquitous and feature the special ESP-Now mode. A Wemos D1 mini board has an onboard regulator with typically much lower quiescent current than the similar NodeMCU. I've measured the Wemos D1 mini deep sleep current before at about 0.16 mA.
If we power the entire circuit with a cheap 18650 battery of 2000mAh, it should last > 10000 hours in standby.
Suppose a skip takes 5 seconds of run-time at 100 mA. That's about 0.14 mAh per skip, so the button should last > 10000 skips.
The skip button is wired such that the actual physical button just wakes up the ESP8266.
The receiver/master is connected to a raspberry pi or similar, with the EspNowSkip receiving packets from the air and sending them over serial to the raspberry pi.
Source code
Proposed EspNowSkip protocol
It could work something like this:
  • there are two roles:
    • a single central "master" node
    • one or more "slave" skip-buttons
  • when the skip button is pressed, it wakes up from deep sleep and sends an ESP-Now "SKIP" message to the last known channel and MAC address of the central node
    • if the skip button doesn't receive an ACK from the central node, it starts a kind of discovery to re-establish the channel and MAC address of the central node
  • the central node sets up an AP by name (e.g. "espnow-revspace")
  • the discovery procedure tries to find the central node by name, this AP name is the only thing that needs to be agreed upon in advance between master and slave code
    • from the AP name, the slave node can do a scan to determine the wifi channel and MAC address to use
    • the slave node keeps both wifi channel and MAC address in (emulated) EEPROM and goes back to sleep
References
