EspNowSkip
| Project EspNowSkip | |
| 350px | |
| Muziekskipknop op basis van ESP-now protocol | |
| Status | Initializing |
| Contact | bertrik, jelly |
| Last Update | 2018-05-05 |
- the skip button should be mobile, so it is battery powered
The ESP-now protocol is connectionless, you don't need to set up a session/get an ip-address to communicate between nodes.
Proposed EspNowSkip protocol
For the EspNow skip button it could work something like this:
- there are two roles:
- a single central "master" node
- one or more "slave" skip-buttons
- when the skip button is pressed, it wakes up from deep sleep and sends an ESP-now "SKIP" message to the last known channel and address of the central node
- if the skip button doesn't receive an ACK from the central node, it starts a kind of discovery to re-establish the channel and address of the central node
- the central node sets up an AP by name (e.g. "espnow-revspace") and broadcasts an ESP-now packet regularly (say every 10 seconds).
- the discovery procedure tries to find the central node by name, this AP name is the only thing that needs to be agreed upon in advance between master and slave code
- from the AP name, the slave node can determine the wifi channel to use
- from the AP broadcast packet, the slave node can determine the master MAC address to send to
- the slave node keeps both wifi channel and MAC address in (emulated) EEPROM and goes back to sleep
