Pov
what is it
POV is the (virtual) server managing the webcams. It stores video files of all webcams over the last 2 days.
OS specifications
  • debian stretch
  • 32b
  • virtual machine with 2 cores
  • 1GB ram
  • 10GB root filesystem
  • 100GB storage for camera files
software
motion
  • motion is installed from the debian repository
  • configuration files are under /etc/motion
  • main configuration is motion.conf which includes cam*.conf
  • as by the design of motion, all its cameras (6 + 11) are monitored from 1 process
constatus
  • installed from the github repository https://github.com/flok99/constatus
  • installed under /usr/local/constatus
  • started (currently, 20170903) from /etc/rc.local
  • each camera has its own constatus process - the idea is that if something crashes, that not all cameras will go down
  • video archive can be viewed under http://10.42.19.84:port/ where port is 8101 for camera 1, 8102 for camera 2 and so on
The configuration files are JSON files. They consist of 2 or more sections: general, source and then optional sections. Every other section (apart from video loopback) have an array of entries for their data. E.g.
Recording Specifications
  • 5 FPS video files
  • 2 FPS HTTP web interface
Cameras
Number Port Physical device protocol Where
CAM 1 8084 RTSP hanging above the 3D printer
CAM 2 8085 MJPEG cantina/kitchen
CAM 3 8086 MJPEG back side of klusruimte
CAM 4 8087 MJPEG front side of klusruimte
CAM 5 8088 RTSP houtbewerkingsruimte (woodworking shop)
CAM 6 broken
CAM 7 8090 MJPEG, source is Verint Nextiva these produce an RTP stream which are converted to MJPEG by scripting running on the shell server, see https://github.com/Peetz0r/revcaminfra.
CAM 8 8091
CAM 9 8092
CAM 10 8093
CAM 11 This one goes up to eleven?! (this camera doesn't actually exist yet)
