CC2540
Revision as of 17:46, 16 November 2016 by Bertrik Sikken (talk | contribs)
Project CC2540
Making the CC2540 BLE dongle work
Status Initializing
Last Update 2016-11-16
This page is about the CC2540 bluetooth low-energy sniffer dongle and getting it to work with Linux. A nice end result could be that it becomes possible to sniff directly in WireShark with this dongle.
I have such a "WeBee" dongle that can be found for about E15,- on websites like Aliexpress.
It's supposedly a CC2540 (or compatible) dongle, the USB id is 0451:16b3.
Interesting links:
Analysis
USB descriptor
When plugging this stick into a Linux machine, you can see it uses only one bulk endpoint.
XXX
USB logs from Windows
This USB device does actually work with Windows:
I've captured a log of the communication over USB while the BLE is capturing bluetooth traffic from some iBeacon, using USB pcap.
In the logs, I cannot see any firmware blobs being downloaded to the stick. Probably the stick comes with a pre-loaded firmware of itself to do the BLE sniffing.
Protocol
In the windows sniffer software, it seems there are only two things communicated:
  • towards the stick: which radio channel to sniff, and some other radio settings
  • from the stick: raw sniffed BLE frames
I can see a lot of similarities between the USB log and the BLE sniffer log. The bulk USB data starts off with two bytes indicating the length of the rest of the data.
