ElectronicsPartsList
List of electronics parts for the space
Resistor 6 series 10 -> 1M (available, somewhat)
Capacitor 6 series 10 -> 1M (available, somewhat)
If the order ID is just a number see Farnell
| *Part* | *Count* | *Use* | *Order ID* | *Price* | *Available in space* | |E6 series resistors|1||1170593|41.48|Half a kit left with 10pcs | |1kOhm resistor 1/4w|100|One of the most commonly used|1700251|1.1|| |0.1uF 50V decoupling cap|100|decoupling, common use|1692300|9|| |10uF 35V decoupling cap|100|decoupling, charge pump, common|9452281|1.7|| |1N4148|500|small signal diode|368106|2.00|| |1N4007|100|general purpose high voltage diode (coil supression, etc)|9565051|8.70|| |1N5226B|50|3.3 volt zener|1700785|3.65|| |1N5231B|50|5 volt zener|1612371|1.25|| |MPF 102|50|small JFET|1467954|9,55|| |BC547|200|small signal NPN BJT, higher voltage then BC558|||availible need to count|| |BC557|200|small signal PNP BJT, higher voltage then BC558|||availible need to count || |2N2222|100||1611371|4.70|| |TIP41C|10|power transistor NPN 5A|9804170|7.90|| |TIP42C|10|power transistor PNP 5A|9804196|7.20|| |2N3055|10|High power transistors 15A NPN|||available|| |MJ2955|5|High power transistor 15A PNP|||| |3,3 V REG, LDO 250MA, TO-92-3|25||1331485|12.75|| |3,3 V REG, LDO 1.5A, TO-220|25||7208324|5.64|| |5 V REG, LDO 250MA, TO-92-3|25||1331481|8.5|| |5 V REG, LDO 1.5 A, TO-220|25||7208324|5.64|| |MAX232|10|TTL <-> RS232C ? IC|1470445|4.40 || |741|20|The absolute classic opamp|1564944|3.8||| |OPA2337|10|General purpose opamp rail-to-rail|1097410|12.20|| |TL074CN ?|20|Generic 4 in one opamp|9755934|6.4|| |LM358|10|very linear opamp high gain|1459520|3.7|| |LM311|20|Comperator|2293183|2.86|| |DE-9|10|DB-9|150726|6|| |RJ-45|20||1284342|13.8|| |2.54mm terminals 2xX breakable male|2|IDE style connector|3418560|6.66|| |2.54mm terminals 1xX breakable male|4|IDE style connector|1580056|6.12|| |2 mm terminals 1xX breakable male|1|laptop IDE style connector|672002|3.17|| |2.54mm terminals 2xX breakable female|2|IDE style connector|1322596|13.56|| |2.54mm terminals 1xX breakable female|4|IDE style connector|1322595|13.48|| |2 mm terminals 1xX breakable female|1|laptop IDE style connector|9728937|7.47|| |Barrel socket, low voltage, 2.1mm|20|Generic power input connector|1216726|14.2|| |2x AA battery holder|10||||10 +/- | |9V battery holder|10||||10 +/-| |100KOhm potmeter|25||||available 20 +/-|| |10KOhm potmeter|25||||| |USB cables (normal, mini, micro, groot voor arduino's, etc..)||||| |ATTiny4313|10|20 pins AVR USBTiny geschikte, maar dan met 4kB flash|1841620|22.||| |ATMega328p|20|same AVR as Arduino uses|1715487|63|| |ATTiny85|10|8-pins AVR, 8 kB flash|1455162|20.3|| |ATTiny44|10|14-pins AVR, 4 kB flash|1455150|12.5|| |MSP430G2231 ?|10|Valueline, identiek aan die in Launchpad|1812192|11.9|| |Resonator 12Mhz|20|Needed for soft USB|1448128|7|| |Resonator 16Mhz|10||1448129|3.5|| |Resonator 20Mhz|30||1448130|10.5|| |Resonator 10Mhz|10||1448127|3.5|| |Resonator 8Mhz|10||1448126|3.5|| |Crystal 32.687kHz|20|Watch crystal|1611828|2.66|| |USB mini-B|15||1696540|11.4|| |USB B|15||1308876|6.45|| |IR LED 940NM, 20� angle, 130mW/Sr|20||1328299|6.4|| |16x2 HD44780 character display|32|Via SA007 kopen|||| |Darlington Array 7 NPN ULN2003A ?|20||1210973|4.2|| |Darlington Array 8 NPN ULN2804A ?|10||1047762|5.1|| |74HC00 quad 2-input NAND|20||380349|3.16|| |74HC02 quad 2-input NOR|20||380350|3.36|| |74HC08 quad 2-input AND|20||1013913|5|| |74HC86 quad 2-input XOR|20||380490|3.36|| |74HC393 dual 4-bit binary counter|10||380799|4.1|| |74HC374 8-bit latch|10||380763|2.8|| |74HC595 8-bit shift register serial to parralel|20|Generic, chainable|3166028|7.6|| |74HC165 8-bit shift register parralel to serial|20|Generic, chainable|380635|5.|| |NE555|20||9589899|7.2|| |NE556|20||9589910|5.8|| |Push button NO wire|30||1634688|20.1|| |Push button NC wire|10||1634693|7|| |Push button NO PCB|50||1813631|16.5|| |SPDT PCB|10||9472983|13.1|| |SPDT rocker|20||1454380|11.6|| | *Total* | | | | %CALC{"$SUM( $ABOVE() )"}% | |
mouser
| *Part* | *Count* | *Use* | *Order ID* | *Price* | *Available in space* | | Sockets voor alle ICs | xxx | | [httphttp://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=d45d0df301 Winkelwagentje] | 37.36 | | | IR LED 940NM, wide angle| 1000 | Walter betaald | Mouser: 638-IR333C/H0/L10 | 62.00 | | | *Total* | | | | %CALC{"$SUM( $ABOVE() )"}% | |
leds-buy.nl
Prijs van onderstaande is EUR 62.60 :
| *Part* | *Count* | *Use* | *Order ID* | *Available in space* | | RGB LED 25� 10mm | 10 | | [httphttp://www.ledsbuy.nl/fullcolorled25graden10mmca-p-951.html shop] | | | RGB LED 25� 5mm | 25 | | [httphttp://www.ledsbuy.nl/fullcolorled25graden10mmca-p-852.html shop] | | | RGB LED 90� 5mm | 10 | | [httphttp://www.ledsbuy.nl/fullcolorled25graden10mmca-p-851.html shop] | | | 7-segment green | 12 | | [httphttp://www.ledsbuy.nl/1cmsegmentdisplaygroen-p-309.html shop] | | | 7-segment orange | 12 | | [httphttp://www.ledsbuy.nl/1cmsegmentdisplaygroen-p-310.html shop] | | | 7-segment red | 12 | | [httphttp://www.ledsbuy.nl/1cmsegmentdisplaygroen-p-312.html shop] | |
