ZX81PLUS35 ZX81 clone
Project ZX81+35 ZX81 clone
My clone of the Sinclair ZX81
Contact Mahjongg
Last Update 2016-09-05
As for now comments and questions on the design can be made here [3] (raspberry PI forum off topic section)  :-)
Introduction to the ZX81+35
3D Preview of early ZX81+34
Schematic 81+34
The old (version 1) schematic of revision 2.0 (.PDF) can be found here: File:ZX81+34 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: File:ZX81+34 kleur REV 2.0.pdf.
The Bill of Material (BOM) for the original ZX81+34 can be found here File:Z81+34 BOM.ods
Layout ZX81+34
Keyboard for ZX81+34/35
File:Nieuw keyboard ZX14.pdf
A version that supports the ZXPand can be downloaded here: File:New ZX81+34 keyboard ZXPand version.pdf
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
Here is the new schematic revision 2.1: A .PDF of the new schematic can be found here: File:ZX81+34 rev 2.1.pdf
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
To make a long story short I indeed accepted that the line counter should be synced with intack, not kept pending for the duration of VSYNC like my earlier version, that also meant I had to re-think the logic for HSYNC and porch generation. While doing that I discovered my earlier porch logic was faulty (used the low nibble, instead of the high nibble of the counter), anyway the new logic should generate a sixteen cycle HSYNC signal sixteen cycles after the intack, and the back porch lasts 16 cycles after that. Here is a .PDF of the latest schematic, revision 2.2; File:ZX81+35 REV 2.2.pdf a coloured version is here: File:ZX81+35 REV 2.2 color.pdf.
29 DECEMBER 2015
30 December 2015
5 January 2016
10 January 2016
23 January 2016
The .JPG can be downloaded here; File:ZX81+35 rev2.2 - Bill Of Materials.pdf and the .ODF spreadsheet here: File:ZX81+358 rev2.2 Bill Of Materials.ods
31 January 2016
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
File:ZX81+35 REV 2.3.pdf
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
here is the updated .PDF, further updates are likely: File:ZX81+35 REV 3.0.pdf
This is how I envision what a ZX81+35 expansion board could look like
This means I will have every limited access to RevSpace :-( The good new is that I now know that I have Sleep Apnea (Apneu in Dutch) which means that I have over 30 breathing stops in my sleep each night, which nearly wake me up. Its the reason for being tired all the time, and for my subconscious fear of going to bed which has lead to a very strange biorhythm. Also good news is that apnea is treatable, with an overpressure (APAP) device I will need to wear in my sleep, I will get a test for one next week (normally it takes over a week, so I'm lucky). Id did a sleepover at MCH and can say the APAP device worked very well for me, I will be offered one in two to three weeks time, I can't wait! If I used it for 2 months and it works well, I will get my permission to drive back.
I tried to design a schematic of the original Zon-81 before creating my own compatible version. A first (unfinished) version of the schematic can be found here: File:Sound expansion (preliminary).pdf
Its development is described in its own article here https://revspace.nl/Zon_X-81_Programmable_Sound_Generator_expansion_for_ZX81%2B35#My_own_.28ZX81.2B35.29_version
While designing the PSG expansion board I look once again to the expansion port and made a discovery that made me say some expletives! I've made a mistake in the very beginning about the orientation of the expansion connector, such that it is now upside-down to how it should have been. This error is expressed in how the expansion connector was drawn, with pin 1 on top, and pin 23 on the bottom, but the edge connector should have been just rotated 90 degrees clockwise, which means pin 1 should have been on the bottom, not on the top!
So I started by modifying the schematic, so it corresponds with how it should be laid out. this is the new schematic, I consider the change big enough to warrant updating to revision 4.0: File:ZX81+35 REV 4.0.pdf
I have also started on the re-layout work. Now done three evenings of layout edits, its September already and it's still not finished, its proven to be really difficult, hold on will need a couple of Thursday evenings more.... also thinking about a trick to keep video stable in turbo mode, it seems the trick is to lower the clock at the very start of each video line, during the line counter reset, that should be doable. But I still must test if that works. The layout edits now also include the edge connector clock is a steady 3.25MHz clock, and NOT the CPU clock, so PSG should be able to work in turbo mode.
