ZX81PLUS35 ZX81 clone
The ZX81+35, previously called the ZX14, and ZX15, and ZX81+34 (2015 Version) retro homecomputer is a much improved Sinclair ZX81 [1] clone built with the modern materials techniques and components of 2015. The ZX81+35 will be built and tested in 2016.
Introduction to the ZX81+35
3D Preview of early ZX81+34
Schematic 81+34
The old (version 1) schematic of revision 2.0 (.PDF) can be found here: File:ZX81+34 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: File:ZX81+34 kleur REV 2.0.pdf.
The Bill of Material (BOM) for the original ZX81+34 can be found here File:Z81+34 BOM.ods
Layout ZX81+34
Keyboard for ZX81+34/35
A version that supports the ZXPand can be downloaded here: File:New ZX81+34 keyboard ZXPand version.pdf
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
Here is the new schematic revision 2.1: A .PDF of the new schematic can be found here: File:ZX81+34 rev 2.1.pdf
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
To make a long story short I indeed accepted that the line counter should be synced with intack, not kept pending for the duration of VSYNC like my earlier version, that also meant I had to re-think the logic for HSYNC and porch generation. While doing that I discovered my earlier porch logic was faulty (used the low nibble, instead of the high nibble of the counter), anyway the new logic should generate a sixteen cycle HSYNC signal sixteen cycles after the intack, and the back porch lasts 16 cycles after that. Here is a .PDF of the latest schematic, revision 2.2; File:ZX81+35 REV 2.2.pdf a coloured version is here: File:ZX81+35 REV 2.2 color.pdf.
29 DECEMBER 2015
30 December 2015
5 January 2016
Here is the latest preview, seen from the front of the board, the picture is fully updated, and also includes the planned ZX81+35's expansion board.
10 January 2016
23 January 2016
The .JPG can be downloaded here; File:ZX81+35 rev2.2 - Bill Of Materials.pdf and the .ODF spreadsheet here: File:ZX81+358 rev2.2 Bill Of Materials.ods
31 January 2016
Well, the PCB for revision 2.2 of my ZX81 + 35 (35 years after the launch of the ZX81, and almost exactly a year after version 1.0) was finally ordered, and I got an e-mail from Eurocircuits with a preview of the PCB, which I don't want to keep from you.
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
There were some teething problems, but I managed to get my ZX81 clone working! Not that I'm satisfied, its still far from a state I would be completely satisfied with it. To start with the keyboard is not wired up correctly, and not all keys are working, in fact it was a struggle to produce the "hello world" text you see in the picture below. Also I am not satisfied with the black letters on a white background, the letters are very thin, so I jumpered the board up to produce white text on a black background, as you can see in the picture below (sorry the picture is a bit fuzzy).
In the coming weeks I will endeavor to find all the problems, and fix them.
