NRF52840
| Project NRF52840 | |
| File:Nopicture.jpg | |
| Investigating Arduino on inexpensive NRF52840 boards | |
| Last Update | 2025-11-29 |
Intro
NRF52840 is potentially a very nice platform:
- low-power. quick wake-up
- inexpensive
- decent amount of flash (1024k), RAM (256k) and CPU cycles (64 MHz)
- support various radio protocols like zigbee, ble, thread, matter, enhanced shockburst
- built-in support for quadrature counting
- looks like it can run arduino too
The boards I have are the "promicro" and "supermini".
Links:
- Nordic technical documentation: https://docs.nordicsemi.com/category/nrf52840-category
- Here is a wiki full of useful information on specific boards: https://github.com/joric/nrfmicro/wiki
- Specifically the supermini https://github.com/joric/nrfmicro/wiki/Alternatives#supermini-nrf52840
- See also https://github.com/pdcook/nRFMicro-Arduino-Core
- https://github.com/ICantMakeThings/Nicenano-NRF52-Supermini-PlatformIO-Support
My promicro board currently has bootloader 0.6.0:
UF2 Bootloader 0.6.0 lib/nrfx (v2.0.0) lib/tinyusb (0.10.1-41-gdf0cda2d) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7) Model: nice!nano Board-ID: nRF52840-nicenano SoftDevice: not found Date: Jun 19 2021
My supermini board came with bootloader 0.6.0:
However the eco-system of inexpensive boards is a complicated landscape:
- AliExpress sellers offer "promicro" and "supermini" board with unclear characteristics
- LEDs are often swapped (blue = hardware charge, red = software led?)
- Various firmware upload interface options (which one to use?):
- Using nrfutil, sends a .zip file containing various parts
- Serial DFU, used by nrfutil?
- Mass storage UF2, possibly activated using the double-reset
- SWD debug interface (requires soldering!)
- Confusing situation regarding bootloaders:
- Most boards seem to come with a modified version of a bootloader meant for another type of board
- Type of bootloader depends on type of firmware you want to run, "ZMK", Arduino using Arduino IDE, Arduino using platformio
- Space for "SoftDevice" needs to be reserved, what is this?
- Risk of accidentally overwriting the bootloader, with UF2 flash offsets sometimes being absolute, sometimes being relative
- Even multiple levels of bootloader? Like the normal one during application and another one using the double-reset method?
Getting 'circuitpython' to work:
- Here's a page on making it work on nicenano: https://circuitpython.org/board/nice_nano/
- HOWEVER, it also says "On nRF boards, CircuitPython 8.2.0 and later require UF2 bootloader version 0.6.1 or later. Older bootloaders cannot load the firmware. See Update UF2 Bootloader below.". Guess what bootloader came with my board ... 0.6.0
- They point you to https://github.com/adafruit/Adafruit_nRF52_Bootloader/releases/tag/0.9.2 but now what!?!!!
