Karaburan
Project Karaburan
Monitoring water quality
Status Initializing
Last Update 2024-07-07
  • write python scripts
    • arduino turbidity
    • turbidity-to-mqtt
  • hook things into systemd / udev
    • e.g. insert GPS -> create symlink with udev -> trigger (re)start of gpsd
USB HID as analog input
An stm32 based bluepill board can be flash with firmware to allow analog input to be exposed as USB HID.
How to flash the stm32:
  • connect an stm32 bluepill to an stlinkv2
  • install openocd
  • flash the freejoy firmware the following
    • download the firmware from XXX
    • create a symlink to the hex file called firmware.hex
    • flash the initial firmware using
influxdb
investigate RTK GPS
Topics:
  • air quality sensors
    • ammonia
    • NOx
  • water chemical analysis
    • nitrates
    • ammonia
    • dissolved oxygen
    • sulfide/sulfate
    • phosphates?
    • salinity (chlorides?)
  • water physical analysis
    • temperature
    • depth?
  • boat control
    • trajectory -> steering
  • camera control
  • post-processing
    • data presentation
      • video/photo stitching
      • time lapse view
      • map view of properties
  • use cases
    • minimum viable prototype
  • materials
    • boat selection
Air quality sensors
Nitrogen compounds in air
  • NOx: 27.3 ug/m3
  • NO2: 18.6 ug/m3 (9.9 ppb)
Water physical analysis
Turbidity / clarity
Boat control
  • 2.4 GHz working frequency
  • 500m range
Interesting links:
remote control
Parts:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
Detect/find pollution source
Implementation
reading temperature sensor
Preparation:
 sudo adduser <name> dialout
Setting up the hardware:
Setting up the software:
  • Install openwire fs
 sudo apt install owfs
 sudo mkdir /mnt/1wire
 server: device = /dev/ttyUSB0
 mountpoint = /mnt/1wire
 allow_other
  • Configure systemd services
 sudo systemctl disable owftpd
  • Start the systemd service
  • Check the logs
 http://localhost:2121 or
 http://raspberrypi.local:2121
