LDAP/OpenLDAP configuration
Revision as of 10:53, 7 April 2024 by Shiz (talk | contribs) (Fix formatting on base configuration directory example)
The below configuration is used for LDAP at RevSpace, written for and tested with FreeRADIUS 2.5.13. The paths are relative to the base configuration directory, e.g. /etc/ldap.
ldap.conf
# needed for anything using libldap
TLS_CACERT /etc/ssl/certs/ca-certificates.crt
TLS_CACERTDIR /etc/ssl/certs
slapd.conf
# Schemas.
include /etc/ldap/schema/core.schema
include /etc/ldap/schema/cosine.schema
include /etc/ldap/schema/inetorgperson.schema
include /etc/ldap/schema/rfc2307bis.schema
include /etc/ldap/schema/openssh-lpk.schema
# Server
pidfile /run/slapd/slapd.pid
include /etc/ldap/slapd/local.conf
security tls=1
disallow bind_anon
require LDAPv3 bind authc strong
loglevel none
moduleload deref.la
moduleload syncprov.la
# Database.
database        ldif
suffix          "dc=space,dc=revspace,dc=nl"
rootdn          "cn=admin,dc=space,dc=revspace,dc=nl"
rootpw          "{CRYPT}$6$rounds=42000$<EXPUNGED>"
directory       /var/lib/ldap/data
password-hash {CRYPT}
password-crypt-salt-format "$6$rounds=42000$%.16s"
overlay deref
include /etc/ldap/slapd/db.replication.conf
include /etc/ldap/slapd/db.acl.conf
slapd/
node.conf
# per-server local node configuration
serverid 1
TLSCACertificateFile /var/lib/dehydrated/certs/ldap2.space.revspace.nl/fullchain.pem
TLSCertificateFile /var/lib/dehydrated/certs/ldap2.space.revspace.nl/cert.pem
TLSCertificateKeyFile /var/lib/dehydrated/certs/ldap2.space.revspace.nl/privkey.pem
# TLSCipherSuite SECURE256:!AES-128-CBC:!ARCFOUR-128:!CAMELLIA-128-CBC:!3DES-CBC:!CAMELLIA-128-CBC:!NULL
db.replication.conf
overlay syncprov
syncrepl rid=1
         provider=ldaps://ldap2.space.revspace.nl
         bindmethod=simple
         binddn="cn=repl-ldap2,ou=services,dc=space,dc=revspace,dc=nl"
         credentials="<EXPUNGED>"
         searchbase="dc=space,dc=revspace,dc=nl"
         schemachecking=on
         type=refreshAndPersist
         retry="60 +"
#syncrepl rid=2
#         bindmethod=simple
#         binddn="cn=repl-ldap2,ou=services,dc=space,dc=revspace,dc=nl"
#         credentials="<EXPUNGED>"
#         searchbase="dc=space,dc=revspace,dc=nl"
#         schemachecking=on
#         type=refreshAndPersist
#         retry="60 +"
mirrormode on
db.acl.conf
# User-changeable attributes
access to dn.subtree="ou=people,dc=space,dc=revspace,dc=nl" attrs=sshPublicKey,userPassword,loginShell
	by self write
	by group="cn=board,ou=groups,dc=space,dc=revspace,dc=nl" write
	by dn.exact="cn=sshpubkey,ou=services,dc=space,dc=revspace,dc=nl" write
	by dn.exact="cn=shelldap-gateway,ou=services,dc=space,dc=revspace,dc=nl" write
	by dn.exact="cn=ldap-sync-scriptje,ou=services,dc=space,dc=revspace,dc=nl" write
	by dn.subtree="ou=services,dc=space,dc=revspace,dc=nl" read
	by * auth
# Users
	by self read
	by * auth
# Groups
access to dn.subtree="ou=groups,dc=space,dc=revspace,dc=nl"
	by * read
# Fallback
access to *
	by * read
schema/
rfc2307bis.schema
Taken from: https://github.com/jtyr/rfc2307bis/tree/4fb02fcfc5816e62716e34a9e27c506e2bedd9c8
# Extracted from: http://tools.ietf.org/html/draft-howard-rfc2307bis-02
# Builtin
#attributeType ( 1.3.6.1.1.1.1.0 NAME 'uidNumber'
#    DESC 'An integer uniquely identifying a user in an
#          administrative domain'
#    EQUALITY integerMatch
#    ORDERING integerOrderingMatch
#    SYNTAX 1.3.6.1.4.1.1466.115.121.1.27
#    SINGLE-VALUE )
# Builtin
#attributeType ( 1.3.6.1.1.1.1.1 NAME 'gidNumber'
#    DESC 'An integer uniquely identifying a group in an
#    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.2 NAME 'gecos'
    DESC 'The GECOS field; the common name'
    EQUALITY caseIgnoreMatch
    SUBSTR caseIgnoreSubstringsMatch
    SYNTAX 1.3.6.1.4.1.1466.115.121.1.15
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.3 NAME 'homeDirectory'
    DESC 'The absolute path to the home directory'
    EQUALITY caseExactIA5Match
    SYNTAX 1.3.6.1.4.1.1466.115.121.1.26
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.4 NAME 'loginShell'
    DESC 'The path to the login shell'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.5 NAME 'shadowLastChange'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.6 NAME 'shadowMin'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.7 NAME 'shadowMax'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.8 NAME 'shadowWarning'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.9 NAME 'shadowInactive'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.10 NAME 'shadowExpire'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.11 NAME 'shadowFlag'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.12 NAME 'memberUid'
    EQUALITY caseExactMatch
    SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 )
attributeType ( 1.3.6.1.1.1.1.13 NAME 'memberNisNetgroup'
attributeType ( 1.3.6.1.1.1.1.14 NAME 'nisNetgroupTriple'
    DESC 'Netgroup triple'
attributeType ( 1.3.6.1.1.1.1.15 NAME 'ipServicePort'
    DESC 'Service port number'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.16 NAME 'ipServiceProtocol'
    DESC 'Service protocol name'
attributeType ( 1.3.6.1.1.1.1.17 NAME 'ipProtocolNumber'
    DESC 'IP protocol number'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.18 NAME 'oncRpcNumber'
    DESC 'ONC RPC number'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.19 NAME 'ipHostNumber'
    DESC 'IPv4 addresses as a dotted decimal omitting leading
          zeros or IPv6 addresses as defined in RFC2373'
    EQUALITY caseIgnoreIA5Match
    SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 )
attributeType ( 1.3.6.1.1.1.1.20 NAME 'ipNetworkNumber'
    DESC 'IP network omitting leading zeros, eg. 192.168'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.21 NAME 'ipNetmaskNumber'
    DESC 'IP netmask omitting leading zeros, eg. 255.255.255.0'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.22 NAME 'macAddress'
    DESC 'MAC address in maximal, colon separated hex
          notation, eg. 00:00:92:90:ee:e2'
attributeType ( 1.3.6.1.1.1.1.23 NAME 'bootParameter'
    DESC 'rpc.bootparamd parameter'
attributeType ( 1.3.6.1.1.1.1.24 NAME 'bootFile'
    DESC 'Boot image name'
attributeType ( 1.3.6.1.1.1.1.26 NAME 'nisMapName'
    DESC 'Name of a generic NIS map'
    SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{64} )
attributeType ( 1.3.6.1.1.1.1.27 NAME 'nisMapEntry'
    DESC 'A generic NIS entry'
    SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{1024}
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.28 NAME 'nisPublicKey'
    DESC 'NIS public key'
    EQUALITY octetStringMatch
    SYNTAX 1.3.6.1.4.1.1466.115.121.1.40
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.29 NAME 'nisSecretKey'
    DESC 'NIS secret key'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.30 NAME 'nisDomain'
    DESC 'NIS domain'
    SYNTAX 1.3.6.1.4.1.1466.115.121.1.26{256} )
attributeType ( 1.3.6.1.1.1.1.31 NAME 'automountMapName'
    DESC 'automount Map Name'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.32 NAME 'automountKey'
    DESC 'Automount Key value'
    SINGLE-VALUE )
attributeType ( 1.3.6.1.1.1.1.33 NAME 'automountInformation'
    DESC 'Automount information'
    SINGLE-VALUE )
objectClass ( 1.3.6.1.1.1.2.0 NAME 'posixAccount' SUP top AUXILIARY
    DESC 'Abstraction of an account with POSIX attributes'
    MUST ( cn $ uid $ uidNumber $ gidNumber $ homeDirectory )
    MAY ( userPassword $ loginShell $ gecos $
          description ) )
objectClass ( 1.3.6.1.1.1.2.1 NAME 'shadowAccount' SUP top AUXILIARY
    DESC 'Additional attributes for shadow passwords'
    MUST uid
    MAY ( userPassword $ description $
          shadowLastChange $ shadowMin $ shadowMax $
          shadowWarning $ shadowInactive $
          shadowExpire $ shadowFlag ) )
objectClass ( 1.3.6.1.1.1.2.2 NAME 'posixGroup' SUP top AUXILIARY
    DESC 'Abstraction of a group of accounts'
    MUST gidNumber
    MAY ( userPassword $ memberUid $
          description ) )
objectClass ( 1.3.6.1.1.1.2.3 NAME 'ipService' SUP top STRUCTURAL
    DESC 'Abstraction an Internet Protocol service.
          Maps an IP port and protocol (such as tcp or udp)
          to one or more names; the distinguished value of
          the cn attribute denotes the services canonical
          name'
    MUST ( cn $ ipServicePort $ ipServiceProtocol )
    MAY description )
objectClass ( 1.3.6.1.1.1.2.4 NAME 'ipProtocol' SUP top STRUCTURAL
    DESC 'Abstraction of an IP protocol. Maps a protocol number
          to one or more names. The distinguished value of the cn
          attribute denotes the protocol canonical name'
    MUST ( cn $ ipProtocolNumber )
    MAY description )
objectClass ( 1.3.6.1.1.1.2.5 NAME 'oncRpc' SUP top STRUCTURAL
    DESC 'Abstraction of an Open Network Computing (ONC)
         [RFC1057] Remote Procedure Call (RPC) binding.
         This class maps an ONC RPC number to a name.
         The distinguished value of the cn attribute denotes
         the RPC service canonical name'
    MUST ( cn $ oncRpcNumber )
    MAY description )
objectClass ( 1.3.6.1.1.1.2.6 NAME 'ipHost' SUP top AUXILIARY
    DESC 'Abstraction of a host, an IP device. The distinguished
          value of the cn attribute denotes the hosts canonical
       name. Device SHOULD be used as a structural class'
    MUST ( cn $ ipHostNumber )
    MAY ( userPassword $ l $ description $
          manager ) )
objectClass ( 1.3.6.1.1.1.2.7 NAME 'ipNetwork' SUP top STRUCTURAL
    DESC 'Abstraction of a network. The distinguished value of
          the cn attribute denotes the network canonical name'
    MUST ipNetworkNumber
    MAY ( cn $ ipNetmaskNumber $ l $ description $ manager ) )
objectClass ( 1.3.6.1.1.1.2.8 NAME 'nisNetgroup' SUP top STRUCTURAL
    DESC 'Abstraction of a netgroup. May refer to other
          netgroups'
    MUST cn
    MAY ( nisNetgroupTriple $ memberNisNetgroup $ description ) )
objectClass ( 1.3.6.1.1.1.2.9 NAME 'nisMap' SUP top STRUCTURAL
    DESC 'A generic abstraction of a NIS map'
    MUST nisMapName
    MAY description )
objectClass ( 1.3.6.1.1.1.2.10 NAME 'nisObject' SUP top STRUCTURAL
    DESC 'An entry in a NIS map'
    MUST ( cn $ nisMapEntry $ nisMapName ) )
objectClass ( 1.3.6.1.1.1.2.11 NAME 'ieee802Device' SUP top AUXILIARY
    DESC 'A device with a MAC address; device SHOULD be
    MAY macAddress )
objectClass ( 1.3.6.1.1.1.2.12 NAME 'bootableDevice' SUP top AUXILIARY
    DESC 'A device with boot parameters; device SHOULD be
    MAY ( bootFile $ bootParameter ) )
objectClass ( 1.3.6.1.1.1.2.14 NAME 'nisKeyObject' SUP top AUXILIARY
    DESC 'An object with a public and secret key'
    MUST ( cn $ nisPublicKey $ nisSecretKey )
    MAY ( uidNumber $ description ) )
objectClass ( 1.3.6.1.1.1.2.15 NAME 'nisDomainObject' SUP top AUXILIARY
    DESC 'Associates a NIS domain with a naming context'
    MUST nisDomain )
objectClass ( 1.3.6.1.1.1.2.16 NAME 'automountMap' SUP top STRUCTURAL
    MUST ( automountMapName )
    MAY description )
objectClass ( 1.3.6.1.1.1.2.17 NAME 'automount' SUP top STRUCTURAL
    MUST ( automountKey $ automountInformation )
    MAY description )
objectClass ( 1.3.6.1.1.1.2.18 NAME 'groupOfMembers' SUP top STRUCTURAL
    DESC 'A group with members (DNs)'
    MUST cn
    MAY ( businessCategory $ seeAlso $ owner $ ou $ o $
          description $ member ) )
openssh-lpk.schema
Taken from: https://www.nikhef.nl/pdp/files/packages/mkgroup-sshlpk/openssh-lpk.schema
# LDAP Public Key Patch schema for use with openssh-ldappubkey
# Author: Eric AUGE <eau@phear.org>
# Based on the proposal of : Mark Ruijter
# octetString SYNTAX
attributetype ( 1.3.6.1.4.1.24552.500.1.1.1.13 NAME 'sshPublicKey'
	DESC 'OpenSSH Public key'
	SYNTAX 1.3.6.1.4.1.1466.115.121.1.40 )
# printableString SYNTAX yes|no
objectclass ( 1.3.6.1.4.1.24552.500.1.1.2.0 NAME 'ldapPublicKey' SUP top AUXILIARY
	DESC 'OpenSSH LPK objectclass'
	MUST uid
	MAY sshPublicKey
skel/
README
LDIF files to import in case the complete LDAP data goes poof.
Use like:
for x in $(pwd)/*.ldif; do
	su openldap -s /bin/sh -c "ldapadd -Q -Y EXTERNAL -H ldapi:/// -W -f $x"
done
After that programs like shelldap should work again.
00-root.ldif
dn: dc=space,dc=revspace,dc=nl
objectClass: top
objectClass: dcObject
objectClass: organization
o: RevSpace
01-unit-services.ldif
dn: ou=services,dc=space,dc=revspace,dc=nl
objectClass: top
objectClass: organizationalUnit
ou: services
01-unit-groups.ldif
dn: ou=groups,dc=space,dc=revspace,dc=nl
objectClass: top
ou: groups
01-unit-people.ldif
dn: ou=people,dc=space,dc=revspace,dc=nl
objectClass: top
ou: people
