PowerLight
Project PowerLight | |
Shows mix of dutch electrical power generation as a pie chart on a LED ring | |
Status | Completed |
Contact | bertrik |
Last Update | 2023-11-23 |
The concept
Show the current dutch electrical power generation-mix as pie chart on a LED ring light, with colors representing fractions of a specific power generation source.
For example:
- yellow: solar
- blue: wind
- red: fossil
- green: nuclear
- purple: other/waste
Power generation data
ENTSO-E data
- B01 (biomass): always 0, not useful
- B02: not available
- B03: not available
- B05 (fossil gas): useful
- B06: not available
- B07: not available
- B08: not available
- B10 (hydro): not available
- B11 (hydro): always 0
- B12 (hydro): not available
- B13 (marine): not available
- B14 (nuclear): useful
- B15 (other renewable): not available
- B17 (waste): useful
- B18 (wind offshore): useful
- B19 (wind onshore): useful
- B20 (other): useful
- B16 (solar)
The model I use for the energy generation mix of the Netherlands
For me, the most insightful information came from this article by Bert Hubert: https://berthub.eu/articles/posts/dutch-electrical-power-figures-2/
Main points relevant for me:
- The solar part reported to entso-e is way too small. Note also at for example https://energy-charts.info/charts/energy_pie/chart.htm?l=en&c=NL that the solar part is tiny
- On-shore wind data is unreliable, but off-shore wind data is probably OK
- No biomass data is reported to entso-e
In my backend application, energy generation fractions are calculated as follows:
- solar = B16 (from the time-shifted forecast document A69)
- wind = B18 (offshore, from generation document A75) + B19 (onshore, from time-shifted forecast document A69)
- fossil = B04 (gas) + B05 (coal)
- nuclear = B14
- waste = B17
- other = B20
In the end, all of the electrical generation data used in my backend application is ENTSO-E data.
Data model behind CO2monitor.nl
Analysis:
- Much of the data comes from ENTSO-E, except for at least solar, wind, biomass, WKK
- Biomass data seems to follow the coal data exactly in shape. The sum of the biomass and coal numbers at CO2monitor equal exactly the ENTSO-E hard coal number.
- CO2monitor must be assigning some fraction of the ENTSO-E hard-coal number to biomass, it is unknown how they arrive at this fraction
- The biomass fraction seems to be 1295/2740 = 47.3% (data from 18 november 2023)
Some data from CBS on energy use for electricity production in 2022: https://opendata.cbs.nl/statline/#/CBS/nl/dataset/80030NED/table?fromstatweb
- total energy from coal: 53315 TJ
- total energy from biomass: 34798 TJ
This means a ratio of 39.5% biomass vs (biomass + coal), not exactly the CO2monitor number, but on the same order
Data schedule
Parts:
- LED ring light, for example
- 24-LED ring https://nl.aliexpress.com/item/32963152993.html I like this one, because it is in one piece and inexpensive
- 40-LED ring https://nl.aliexpress.com/item/1005003798658173.html this has 4 segments that you have to join/solder
- 60-LED ring https://nl.aliexpress.com/item/4000102576864.html also 4 segments
- Wemos D1 mini board + pin headers, containing an ESP8266 microcontroller
- "dupont"-cable, 4 wires
- angled pin header, some rings have 2.0 mm pitch, others have 2.54 mm pitch
- USB-A to USB-micro cable
- 5V USB adapter
Connecting it:
- Solder the straight pin headers that came with it on the wemos d1 mini
- Solder the angled pin to the LED ring
- Connect the dupont cable:
- Wemos 5V goes to 5V on the LED ring
- Wemos GND goes to GND on the LED ring
- Wemos D3 goes to DI on the LED ring
- Wemos D2 goes to DO on the LED ring
Diffuser: https://www.thingiverse.com/thing:751894 resize to 89x89x8 mm
- The backend part that collects the power generation data, written in Java, running on a VPS
- The light part that visualizes the power generation as fractions on a LED ring, running on an Arduino
Backend
Runs as a REST-like resource, with the following endpoints:
- http://stofradar.nl:9001/electricity/generation with details (every 15 minutes) about the current (35-50 minute ago) electricity generation mix, units are MW
- http://stofradar.nl:9001/electricity/capacity with currently (per year) installed generation capacity, by source, units are MW
- http://stofradar.nl:9001/electricity/price with day-ahead hourly electricity price-per-MWh for today, in euro/MWh, multiply by 0.001 to get euro/kWh
- http://stofradar.nl:9001/naturalgas/price with daily natural gas prices (neutral gas price) of TTF spot market, in euro/MWh, multiply by 35.17/3600 (= divide by 102.36 approximately) to get euro/m3
- http://stofradar.nl:9001/naturalgas/flow with daily natural gas flows in/out the dutch natural gas system, units are (MWh/day)
Returns JSON-structures like:
{ "time": 1657057500, "total": 9122, "mix": [ { "id": "solar", "power": 0, "color": "#FFFF00"}, { "id": "wind", "power": 4, "color": "#0000FF"}, { "id": "fossil", "power": 86, "color": "#FF0000"}, { "id": "nuclear", "power": 5, "color": "#FF00FF"}, { "id": "other", "power": 4, "color": "#444444"}, { "id": "waste", "power": 1, "color": "#444444"} ] }
- total is the total most recent electrical power (megawatt), suitable for display (on a numeric display inside the ring for example)
- mix is an array of power sources, each with:
- a short unique id
{ "current": { "date": "2022-10-30","price": 32.02 }, "day-ahead": [ { "date": "2022-10-31", "price": 62.631 }, { "date": "2022-11-01", "price": 49.293 } ] }
Display
LED ring energy mix
Hardware that I used:
- Wemos D1 mini, contains an ESP8266 + USB-serial converter
- 24-led pixel ring, for example this one https://nl.aliexpress.com/item/32963152993.html
- "dupont"-cable, you need 4 wires
- wemos 5V to LED ring 5V
- wemos GND to LED ring GND
- wemos D3 to LED ring DI
- wemos D2 to LED ring DO
Firmware installation:
- compiled using platformio
- clone the code from github, enter the PowerLight directory
Configuration:
- connect over WiFi to the "ESP-POWERLIGHT" network (no password)
- open page at 192.168.4.1
- enter WiFi credentials (select a network + password)
LED ring price clock
- LED ring with 24 coloured leds, 2 leds per hour
- colour indicates relative price, green = low, red = high
- indicate current time by making the corresponding LED extra bright
Interesting links:
ElectricityPrice
T-Display
SHA-badge
Micropython:
- ++ possibly quick development, script can be shared with other people
- ++ has working libs for fetching HTTP, decoding JSON, controlling the display
- -- script needs frequent garbage collection to avoid crashing?
- -- unclear how to get a python script on this thing
- -- sha badge firmware bootloops, currently unusable to me
Arduino:
- ++ I know this environment, don't have to debug existing bootlooping firmware, no compiler setup required
- ++ Already have HTTP and JSON working on Arduino
- ++ Code starts immediately, no user interaction required
- -- not sure if there is a usable epaper driver
