MainsFrequency2.0
Project MainsFrequency2.0 | |
A simple mains frequency counter | |
Contact | bertrik |
Last Update | 2023-08-25 |
This has been achieved by using an ESP32c3 board with the 'phasing' algorithm described below. No mains interfacing hardware is required, measurement data can be easily transferred using MQTT over a WiFi network.
Concept
Desired end result:
Phasing algorithm
The algorithm is as follows:
- Sample the mains frequency waveform continuously at 5000 Hz
- Correlate each sample with a perfect 50 Hz reference waveform, by keeping a sum of the waveform multiplied by a cosine (I) and a sum of the waveform multiplied by a sine (Q)
- For each second, calculate the phase using the accumulated I and Q sums with atan2(Q, I).
- The change in phase during one second is directly proportional to the frequency deviation from the 50 Hz reference frequency
This results in:
- A continuous process, with a new frequency value every second
- The algorithm uses *all* of the data contained in one second (there is no single threshold value), thus producing a robust value
- Any DC offset in the mains frequency waveform is automatically balanced out, no need to keep track of the median or quartile values
Zero cross algoritm
This is my older idea for an algorithm to get accurate instantaneous frequency:
Visualisation
- just show the relative phase angle on the LED ring, this could be a single bright pixel for the latest phase measurement and progressively dimmer pixels for older phase measurements.
Mains waveform ring
Concepts:
Calculation:
Luatos ESP32C3
This module (I recommend the one with serial chip) seems to work quite well so far:
- Senses mains waveform from surroundings with just a wire into its ADC input, using the 'phase' software algorithm
The ADC1/UART1 RX pin is the input for 50 Hz. You can just leave that unconnected and it will pick up 50 Hz, or perhaps connect a short piece (20 cm or so) of wire to it.
Using ZMPT101B (old idea
ZMPT101B | Wemos D1 mini | Remark |
GND | GND | Ground |
VCC | 5V | Powers the ZMPT101B from the wemos D1 mini |
OUT | A0 | Analog mains waveform, 0..5V, 180 kohm resistor in series |
To flash the esp32c3 board:
- install platformio
- check out the code
git clone https://github.com/bertrik/MainsFrequency
- enter the esp32c3phase directory
cd MainsFrequency cd esp32c3phase
- connect the board, compile and upload
- connect with serial terminal, to watch frequency measurements
pio device monitor
Integration into revspace sensor infrastructure
There is a measurement device present at revspace (above the green tool board). It sends frequency data to the revspace MQTT server once every 5 seconds.
Processing of this data into something that our grafana can display is unfortunately broken (is that documented somewhere anyway!?)
You can watch the data (using mosquitto for example):
mosquitto_sub -h revspace.nl -t revspace/sensors/ac/frequency -v
Example data:
topic = "revspace/sensors/ac/frequency", payload = "50.025 Hz" (retained)
In the #revspace IRC channel, you can issue a command to show the most recently known value:
!netfrequentie
(where is the script that handles this?) Example data:
23:00 <@bertrik> !netfrequentie 23:00 <@bar> bertrik: 49.898 Hz
