MainsFrequency2.0
Project MainsFrequency2.0 | |
A simple mains frequency counter | |
Contact | bertrik |
Last Update | 2023-05-30 |
Concept
Desired end result:
Algorithm for getting accurate instantaneous frequency out of it:
- Sample the mains frequency waveform during approximately one second (say 5 - 10 kHz)
- Determine the median, lower and upper quartiles of the waveform, and shift data so its values are symmetrically around zero
- Calculate zero crossings by doing linear regression to find the zero-crossing of the wave in the region around the zero crossing (in between the quartile values), this gives sub-sample time resolution
- The linear regression runs a kind of state machine, just keeping track of sum(x), sum(y), sum(x*x), sum(x*y) is enough to perform a linear regression at any time
- Do this over the approximately 50 cycles contained in the one second data and determine average frequency
Ideas:
- While playing around with an STM32 blue pill, it turned out you might not need a mains power interface at all. A piece of wire picks up ambient 50 Hz already. Typical accuracy of the STM32 clock crystal appears a bit lower than that of the ESP8266, but for visualisation this might not be so important. We don't need the WiFi-functionality of the ESP8266 if just visualizing. This simplifies things: required hardware is just bluepill + piece-of-wire + RGB LED ring.
- A raspberry pi pico appears to be able to satisfy many requirements:
- Able to sample mains frequency directly from ambient signals on its sensitive A/D input, without the need for a transformer circuit
- Able to sample a signal with good timing accuracy, it has a crystal better than 30 ppm (0.0015 Hz at 50 Hz)
- Might allow control of a LED ring using FastLED for visualisation (not possible with STM32), to be researched
- Has WiFi support, although rather dodgy on the Arduino platform, for publishing directly to mqtt
- Relatively inexpensive
Visualisation
Mains waveform ring
Concepts:
Calculation:
ZMPT101B | Wemos D1 mini | Remark |
GND | GND | Ground |
VCC | 5V | Powers the ZMPT101B from the wemos D1 mini |
OUT | A0 | Analog mains waveform, 0..5V, 180 kohm resistor in series |
To flash the esp8266:
- install platformio
- enter the esp8266sampler directory
cd esp8266sampler
- compile and upload
