EspAudioSensor
| ESP32-based audio sensor | |
| Last Update | 2023-04-18 |
RIVM noise measuring project:
I would like to build a case like that!
Github links to the project of Marcel Meek / TTN Apeldoorn:
Links back:
- https://iotassistant.io/esp32/smart-door-bell-noise-meter-using-fft-esp32/
- https://en.usini.eu/digital_microphone_on_esp32/
TODO
- figure out which LoRaSoundkit is "current" (most up-to-date) -> this one: https://github.com/meekm/LoRaSoundkit
- figure out alternative pinning for LoRaSoundkit so it works for both TTGO and Heltec boards
- put it together!
Sound meter projects
- LoRa sound kit by Marcel Meek
- DNMS project by Helmut Bitter
- Unknown sensor tested by RIVM in Schiedam (mentioned on https://www.samenmetenaanluchtkwaliteit.nl/nieuws/citizen-science-geluidmetertest-op-rivm-terrein )
- Sound meter by Bart Jurgens uit Amerongen, link ???
- Sound meter from Amsterdam Sounds project , Waag Society, link ???
Ideas
Bluetooth interface
The ESP32 supports bluetooth as an RF technology. It would be nice to be able to quickly see the current/most recently measured data. This can be shown on the display. Perhaps even more convenient, this can be exposed over bluetooth for display on a mobile phone. Are there android apps that can interface with bluetooth?
The Bluetooth specification reserves 0x27C3 as the measurement unit code for sound pressure (dB) and 0x2BE4 as the noise characteristic.
How the BLE indicate and notify work, and the difference between them: https://openlabpro.com/guide/ble-notify-on-esp32-controller/
The concept is the following:
- Every 5 minutes, the measured sound intensity is sent to a central server on the internet. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
- The central server forwards the measurements to sensor.community, from there they are automatically picked up by RIVM
- how often should audio be sampled? 1 second/minute? 10 seconds/min? How long should the audio fragment be?
Theory
A weighting
| Octave start | Octave center | Octave end | Remark |
| 88 Hz | 125 Hz | 177 Hz | |
| 44 Hz | 63 Hz | 88 Hz | |
| 22 Hz | 31 Hz | 44 Hz |
FFT
Links:
Decibel meters
Fairly typical specs:
- dynamic range: 30 - 130 dB
- accuracy: 1.5-2 dB
- norm: EN 61672-1
Ideally, we come up with a pinout that allows both the TTGO and Heltect boards to be used with essentially the same firmware.
NodeMCU ESP32
- INMP441 GND to ESP32 GND
- INMP441 VDD to ESP32 3.3V
- INMP441 SD to ESP32 A4/32
- INMP441 SCK to ESP32 A16/14
- INMP441 WS to ESP32 15
- INMP441 L/R to ESP32 GND
Heltec LoRa32 v2
Microphones
- INMP441: cheap microphone
- SPH0645: untested
ICS-43434: expensive, used in the DNMScan apparently be found more cheaply now, for like $3
Casing
My own initial attempt: lasdoor + wartel + 5/8 inch pvc pipe on the right.
Original experimental code
- Take an audio measurement from a digital microphone at a regular interval.
- On the recorded audio, perform a 4096-point real->complex FFT with a windowing function (flat-top).
- Display as a kind of ASCII-art 'waterfall'.
Citizen science code
firmware
backend code
I have written a forwarder application in Java that takes the data from that sensor from TheThingsNetwork and forwards it to sensor.community:
https://github.com/bertrik/noiseforwarder -> is now integrated in my sensor-data-bridge.
Improvement ideas
To improve on the sound sensor of Marcel Meek, I intend to change the following:
- Make it work on a Heltec LoRa32 v2 board
- This could be just adding a platformio configuration
- Might also require remapping of the pins, since pin 35 (IIS data in) is already used for LoRa DIO1 on the Heltec LoRa32 v2
- Avoid burn-in of the OLED display
- Currently the OLED continuously shows the most recent measurement data, the OLED is known to suffer from burn-in, making the display unreadable after a couple of months
- The plan is to add a timeout, e.g. turn off display after 2 minutes, reactivate by button-press
- Add easier commissioning of LoRaWAN parameters
- Currently the node shows credentials using very small characters
- Nice solution would be to make this machine-readable, like a QR code on the display with TTN credentials as long as it has not successfully joined TTN
- Allow local reading of the most currently measured noise value
- Add a bluetooth BLE GATT interface with the most recently measured dBa value
- Maybe a sensor.community-style web page data.json file?
- Add firmware update interface
- Internal webpage over WiFi that allows you to select a bin file and update the firmware
DNMS
- it needs a custom PCB
- building the firmware is unnecessary complex
DNMS Protocol:
- 1 DNMS_CMD_RESET
- 2 DNMS_CMD_READ_VERSION
- 3 DNMS_CMD_CALCULATE_LEQ
- 4 DNMS_CMD_READ_DATA_READY
- 5 DNMS_CMD_READ_LEQ
- a command looks like this:
Sensor.community protocol
- REST with JSON
Links:
