LoraWanDustSensor
Project LoRaWAN dust Sensor | |
LoRaWAN airborne particulate matter sensor | |
Contact | bertrik |
Last Update | 2022-01-01 |
What is it?
The concept consists of:
Features
- Supported particulate matter sensors (auto-detected):
- Uses LoRaWAN/TheThingsNetwork for communicating the measurement values:
- Hardware is based on off-the-shelf ESP32+LoRa hardware, specifically
- TTGO LoRa32 v1 and
- Heltec LoRa32 v2
- Works with TTNv3, the most recent version of TheThingsNetwork infrastructure
- LoRaWAN OTAA credentials are shown as a QR-code so they are machine-readable
- Data upload interval defaults to 5 minutes (SF7), scales with spreading-factor to satisfy the fair-access-policy of TheThingsNetwork
- Data is encoded over LoRaWAN as Cayenne LPP, no custom payload decoder needed
- Supports WiFi over-the-air firmware upgrade
Similar nodes
- Apeldoorn-in-data
- (others...)
- Automate building and uploading of BIN files on github with github actions/workflows
- Restructure firmware a bit to make the main .ino file smaller
Ideas:
- Make measurement values available through bluetooth
QR code for TheThingsNetwork credentials
- QR contents will be:
- Example content should fit in 29x29 pixel version 3 QR code (format "OTAA:JoinEUI:DevEUI:AppKey" as hexadecimal)
OTAA:1122334455667788:1122334455667788:112233445566778899AABBCCDDEEFF00
Bluetooth interface
There are now official Bluetooth UUIDs for GATT characteristic and object types for PM10, PM2.5 and PM1.0, see page 19 of https://btprodspecificationrefs.blob.core.windows.net/assigned-values/16-bit%20UUID%20Numbers%20Document.pdf
The node is based on Arduino-compatible ESP32 boards with LoRaWAN:
- TTGO LoRa32 V1 ("ttgo-lora32-v1") or the
- The humidity/temperature sensor is the BME280 (superior to the DHT11/22), auto-detected.
- An external SSD1306 display (I2C) can be connected, for easier mounting into the casing and avoiding burn-in the built-in OLED, auto-detected.
Pinout
TTGO LoRa v1 | Heltec LoRa v2 | Sensor | Remark |
5V | 5V | 5V (SDS pin 3) | SPS30 5v (red), triple-check this, swapping 5V/GND destroys the SDS011 |
GND | GND | GND (SDS pin 5) | SPS30 gnd (black), triple-check this, swapping 5V/GND destroys the SDS011 |
GPIO23 | GPIO23 | RXD (SDS pin 6) | SPS30 RX (white?) |
GPIO22 | GPIO22 | TXD (SDS pin 7) | SPS30 TX (purple?) |
3.3V | 3.3V/Vext | BME280 3V | Both Vext and 3.3V can be used |
GND | GND | BME280 GND | ground |
GPIO15 | GPIO15 | BME280 SCL | Piggybacking on the I2C bus to the display |
GPIO4 | GPIO4 | BME280 SDA | Piggybacking on the I2C bus to the display |
For reference:
Note: pins 34, 35, 36, 39 are INPUT ONLY!
Display
The display on the ESP32 LoRa boards is an 128x64 pixel OLED display. It wears out after some months, pixels that have been on more than other pixels will become dimmer.
Hackaday article about this effect. The burn-in/dimming effect is very obvious here.
The firmware tries to auto-detect an external display, and if found, disable the internal display to avoid burn-in.
Things to keep in mind when connecting an external display:
- You need a 128x64 display with I2C interface (not SPI), four pins VDD/GND/SCL/SDA
- Choose either a full yellow or full cyan OLED. OLEDs with *white* pixels seem to burn in quite quickly. Avoid picking a partial yellow/partial cyan OLED, the QR code with LoRaWAN OTAA credentials cannot be displayed correctly on these.
- The pin order appears to vary, in particular take note of VDD and GND, they can be exactly the other way around between models
Firmware
- install platformio:
- get the source from github:
cd LoraWanPmSensor
pio run -e ttgov1 -t upload
pio run -e heltecv2 -t upload
- when source code has updated, run the following and perform the previous step again after that
git pull
Firmware update
Once the initial firmware has been loaded into the device, further firmware updates can be done over WiFi:
- Select the appropriate BIN file, the firmware will be updated and the board reboots
Payload encoding
Cayenne
Optionally:
Example:
Binary
- 1 byte : 0x04
- 2 bytes: PM25(?) big endian
- 2 bytes: PM10(?) big endian
- RIVM node, sends 20 bytes
- 2 bytes pressure (unit?)
- 2 bytes pm10 (unit?)
- 2 bytes pm25 (unit?)
- 2 bytes op1 (unit?)
- 2 bytes op2 (unit?)
- 4 bytes latitude (unit?)
- 4 bytes longitude (unit?)
LoraWan time budget
Consider the following:
In terms of interval:
Downlink commands
I plan the following downlink commands:
Principles:
