AudioMoth
Project AudioMoth
Last Update 2021-04-07
What
I have an AudioMoth board, and plan to improve its software:
Ideas:
Frequency response
See https://circuithub.com/projects/OpenAcoustics/AudioMoth
The microphone is a SPM0408LE5H. Can't find much about its ultrasonic performance. The official graph shows a hint of resonance above 10k so it does have ultrasonic sensitivity. For frequencies higher than the resonance peak the response of a typical microphone drops off steeply with 6 dB/octave. I have been able to record some pipistrelle bats with it (40 - 50 kHz).
The processor is EFM32WG380F256, link
Where is the schematic?
My fork on github: https://github.com/bertrik/AudioMoth-Project
Suggested trigger extension
A bat specific trigger is desireable because this way we only get "interesting" files.
The idea is that bat signals are, in general:
  • ultrasonic, frequency above 10 kHz
  • organised in short pulses, e.g. 8 pulses per second of 5 ms each for a pipistrelle
Challenges:
  • crickets, sound is also at least partly ultrasonic, overlapping with the calls of some of the larger bats and with social bat calls in general
Proposed algorithm:
  1. Apply a high-pass filter at about 10 kHz, this needs not be super-sharp filter. Perhaps just a simple 1-pole IIR (easy to calculate).
  2. Calculate the energy in each millisecond by adding the squared amplitude of the high-pass filtered signal over this millisecond. Perhaps we can also just calculate variance here and forget about step 1).
  3. Calculate a running average energy over several (say 500) of these milliseconds values.
  4. If the millisecond energy exceeds the average energy by a factor X (the sensitivity of the trigger), consider the trigger to be active.
Running the tools
Running the AudioMoth tools (configuration tool, flash tool, etc) requires the --no-sandbox option (at least on my system), for example
 ./AudioMothConfigurationAppSetup1.2.5.AppImage --no-sandbox
IDE for development
A description of all steps to get the firmware compiled is written here: https://github.com/OpenAcousticDevices/AudioMoth-Project/wiki/AudioMoth
Compiling
platformio
It compiles and produces a firmware.bin file, but it's not recognized by the flashing tool as a valid file.
Use this platformio.ini file:
 [platformio]
 src_dir = src,fatfs_src
 include_dir = inc,fatfs_inc
 [env:default]
 framework = zephyr
 platform = siliconlabsefm32
 board = efm32wg_stk3800
Install platformio:
 sudo apt install python3-pip
 sudo pip3 install platformio
 sudo pip3 install -U PyYAML
Compile it:
 pio run
