LoraWanDustSensor
Project LoRaWAN dust Sensor | |
LoRaWAN airborne particulate matter sensor | |
Contact | bertrik |
Last Update | 2021-04-05 |
What is it?
The concept consists of:
Features
- LoRaWAN-enabled particulate matter sensor node, based on off-the-shelf ESP32+LoRa hardware, specifically the TTGO LoRa32 v1 and Heltec LoRa32 v2 board.
- Works with the most recent version (v3) of TheThingsNetwork infrastructure
- Data upload interval defaults to 5 minutes (SF7), scales with spreading-factor to satisfy the fair-use-policy of TheThingsNetwork
- Data is encoded as Cayenne LPP, no custom payload decoder needed
- Supports Nova Fitness SDS011 particulate matter sensor (auto-detected), supports PM10, PM2.5
- Supports Sensirion SPS30 particulate matter sensor (auto-detected), supports PM10, PM4.0, PM2.5, PM1.0
- Supports BME280 humidity/temperature/pressure sensor (auto-detected)
- Firmware can be upgraded over-the-air (WiFi)
Similar nodes
- Apeldoorn-in-data
- (others...)
The node is based on the Arduino framework:
- For the processor board, either the TTGO ESP32 board ("ttgo-lora32-v1") or the Heltec LoRa32 V2 can be used.
- The particulate matter sensor is the SDS011, just like in the sensor.community project. There is experimental support for the SPS30, the sensor type is auto-detected.
- The humidity/temperature sensor is the BME280 (superior to the DHT11/22).
Pinout
TTGO LoRa v1 | Heltec LoRa v2 | Sensor | Remark |
5V | 5V | 5V (SDS pin 3) | triple-check this, swapping 5V/GND destroys the SDS011 |
GND | GND | GND (SDS pin 5) | triple-check this, swapping 5V/GND destroys the SDS011 |
GPIO23 | GPIO23 | RXD (SDS pin 6) | |
GPIO22 | GPIO22 | TXD (SDS pin 7) | |
3.3V | 3.3V/Vext | BME280 3V | Both Vext and 3.3V can be used |
GND | GND | BME280 GND | ground |
GPIO15 | GPIO15 | BME280 SCL | |
GPIO4 | GPIO4 | BME280 SDA |
For reference:
- install platformio:
- get the source from github:
cd LoraWanPmSensor cd Esp32PmSensor
pio run -e ttgov1 -t upload
pio run -e heltecv2 -t upload
On Windows, with the Arduino IDE
- Install the Arduino IDE ...
- Get the ESP32 support package ...
- Install the following libraries
- squix78/ESP8266_SSD1306
- mcci-catena/MCCI LoRaWAN LMIC library, version 3.3.0
- sparkfun/SparkFun BME280
- Set the target to either the TTGO LoRa32 v1 or Heltec LoRa32 v2
- Ctrl-U to compile and upload
Payload encoding
My firmware uses the Cayenne LPP (low power payload) encoding.
Cayenne
Optionally:
Example:
Binary
- 1 byte : 0x04
- 2 bytes: PM25(?) big endian
- 2 bytes: PM10(?) big endian
- RIVM node, sends 20 bytes
- 2 bytes pressure (unit?)
- 2 bytes pm10 (unit?)
- 2 bytes pm25 (unit?)
- 2 bytes op1 (unit?)
- 2 bytes op2 (unit?)
- 4 bytes latitude (unit?)
- 4 bytes longitude (unit?)
LoraWan time budget
Consider the following:
In terms of interval:
Node design
The luftdaten backend has a 5 minute "heartbeat", so at least one measurement per 5 minutes should be sent to avoid disappearing from the map. The node firmware (attempts to) send a message every 4m30s seconds, just like the luftdaten WiFi sensor. A little bit of randomness (30 s) is added to avoid nodes transmitting at exactly the same time over long periods of time and interfering with each other.
- INIT: determine presence of the SDS011, print the SDS011 serial number
- IDLE: wait until the start of the cycle, then turn on the fan
- WARMUP: wait 20 seconds while the sensor "warms up"
- MEASURE: measure 10 seconds, then turn off fan, calculate median/average and send LoRaWAN message
Building with platformio
To compile and upload:
TTN key provisioning
To keep things simple, there is no key provisioning for the nodes themselves. All nodes use the same firmware with the same APP EUI and the same APP KEY. The thing that makes each node unique is its DEVEUI, this is derived from the built-in unique ESP32 id.
On the TTN side, each node will have to be registered by its DEV EUI. The following scheme is used to make TTN provisioning as simple as possible:
- Each node can be programmed with the *same* software, no source code modification is required
- The node administrator needs to enter the following properties at the TTN console, for each node:
- The Device EUI is derived from the node-specific ESP32 MAC address, the node shows this on its OLED
- The App EUI has a fixed value and is the same for all nodes
- The App Key has a fixed value and is the same for all nodes
- Use 32-bit frame counter, leave frame counter checks enabled
The node uses a fixed App EUI and App key by default, but each node can also be configured to use a custom set of OTAA keys.
Backend
This is implemented by my LoraLuftdatenForwarder (source code).
- Subscribes to a TTN MQTT stream and receives incoming messages, both TTN "v2" and "v3" stacks are supported.
- Decodes Cayenne and custom payloads.
- Forwards to sensor.community (formerly luftdaten.info)
- Forwards to opensensemap.org, the opensensebox id is automatically picked up from an attribute specified in the TTN v3 console.
Forward to feinstaub app (experimental), https://pm.mrgames-server.de/
Development
To receive data using mosquitto, separately from the backend:
Example upstream data:
Example downstream data:
Gateway API:
Useful tools:
- packet decoder: https://lorawan-packet-decoder-0ta6puiniaut.runkit.sh/
- airtime calculator: ...
