LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2020-11-24
The concept
The concept consists of:
  • a forwarder application that collects the data from TTN and forwards it to luftdaten.info, opensensemap, mycayenne dashboard, etc.
This has been done before by other people, but it appears there is no universal solution. I am publishing all source code on github and will put up documentation on this wiki. This concept uses Cayenne because it is the closest practical thing towards a universal format but still reasonably compact format.
The OTAA key is hardcoded into the node, the session keys are not. The node identifies itself by its built-in unique ESP32 serial number.
  • each node can be flashed with the same firmware
  • the node shows its unique Device EUI on the OLED
  • at the TTN console, you register the node with the unique Device EUI
  • the sensor node receives encryption keys over the air automatically by OTAA
  • done!
  • implement the ESP-Now lamp/display protocol, see https://revspace.nl/StofAnanas#Next_generation
  • update TTN upload schedule, set interval to luftdaten interval of 5 minutes, add some upload time randomness and avoid synchronised collisions between nodes
  • disable screen when idle, to avoid burn-in of the OLED?
  • internal web server, for configuration, information?
  • firmware update over WiFi
The node is based on the Arduino framework:
  • for the processor board, either the TTGO ESP32 board ("ttgo-lora32-v1") and the Heltec LoRa32 V2 can be used.
  • the particulate matter sensor is the SDS-011, just like in the luftdaten project.
  • the humidity/temperature sensor is the BME280 (superior to the DHT11/22).
TODO: plaatjes van de hardware
Pinout
TTGO LoRa v1 Heltec LoRa v2 Sensor Remark
5V 5V SDS011 5V (pin 3) triple-check this, swapping 5V/GND destroys the SDS011
GND GND SDS011 GND (pin 5) triple-check this, swapping 5V/GND destroys the SDS011
GPIO23 GPIO23 SDS011 RXD (pin 6) (was GPIO25)
GPIO22 GPIO22 SDS011 TXD (pin 7) (was GPIO35)
3.3V 3.3V/Vext BME280 3V Both Vext and 3.3V can be used
GND GND BME280 GND ground
GPIO15 GPIO15 BME280 SCL data
GPIO4 GPIO4 BME280 SDA data
For reference:
TTGO LoRa v1
Technical documents:
Heltec LoRa32 v2
  • install platformio:
 sudo apt install python3-pip
 sudo pip3 install platformio
 pio update
  • get the source from github:
  • enter the correct directory:
 cd LoraWanPmSensor
 cd Esp32PmSensor
  • compile and upload (for TTGO LoRa32 v1 board):
 pio run -e ttgov1 -t upload
  • compile and upload (for Heltec LoRa32 v2 board):
 pio run -e heltecv2 -t upload
On Windows, with the Arduino IDE
  • Install the Arduino IDE ...
  • Get the ESP32 support package ...
  • Install the following libraries
    • ESP8266_SSD1306
    • MCCI LoRaWAN LMIC library, version 3.2.0
    • SparkFun BME280
  • Set the target to either the TTGO LoRa32 v1 or Heltec LoRa32 v2
  • Ctrl-U to compile and upload
Payload encoding
Cayenne
  • PM1.0: digital input (type 2), channel id 0, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3 (optional)
  • PM10: digital input (type 2), channel id 1, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • PM2.5: digital input (type 2), channel id 2, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • Temperature: temperature (type 103), with value in units of 0.1 degrees celcius
  • Humidity: humidity (type 104), with value in units of 0.5 %
  • Pressure: barometer (type 115), with value in units of 0.1 mbar, or 10 Pa (optional)
Example:
Binary
LoraWan time budget
Consider the following:
  • radio regulations generally have a 1% duty cycle requirement for the two bands used by the 8 LoRaWAN (EU) frequencies, so according to the legal limits, there is about 86400x0.01x2 = 1728 seconds per day send time at the best case.
  • TheThingsNetwork has a FUP of 30s of data upload per day, actually a huge restriction compared to the send time allowed purely by radio regulations.
  • The Luftdaten backend appears to run on a 5 minute interval, or 288 measurements per day.
  • The default Luftdaten firmware sends new data every 145s by default
  • skip T/RH/P completely (8 bytes left): SF7 is possible, at SF8 we spend 102 ms per transmission
  • skip P only (15 bytes left): SF7 is possible, at SF8 we spend 123 ms per transmission
Node design
The luftdaten backend has a 5 minute "heartbeat", so at least one measurement per 5 minutes should be sent to avoid disappearing from the map. The node firmware (attempts to) send a message every 4m30s seconds, just like the luftdaten WiFi sensor. A little bit of randomness (30 s) is added to avoid nodes transmitting at exactly the same time over long periods of time and interfering with each other.
  • INIT: determine presence of the SDS011, print the SDS011 serial number
  • IDLE: wait until the start of the cycle, then turn on the fan
  • WARMUP: wait 20 seconds while the sensor "warms up"
  • MEASURE: measure 10 seconds, then turn off fan, calculate median/average and send LoRaWAN message
Building with platformio
 pio update
To compile and upload:
TTN key provisioning
  • Each node can be programmed with the *same* software, no source code modification is required
  • The node administrator needs to enter the following properties at the TTN console, for each node:
    • The Device EUI is derived from the node-specific ESP32 MAC address, the node shows this on its OLED
    • The App EUI has a fixed value and is the same for all nodes
    • The App Key has a fixed value and is the same for all nodes
    • Use 32-bit frame counter, leave frame counter checks enabled
Backend
  • subscribe to a TTN MQTT stream and receive incoming messages
  • decode Cayenne and custom payloads
  • forward to luftdaten.info/sensor.community
  • forward to opensensemap.org
  • forward to feinstaub app (experimental), https://pm.mrgames-server.de/
Development
To receive data using mosquitto, separately from the backend:
Example upstream data:
Example downstream data:
Gateway API:
Useful tools:
