EspAudioSensor
Revision as of 11:40, 15 April 2019 by Bertrik Sikken (talk | contribs)
Project ESP audio sensor
ESP-based audio sensor
Status Initializing
Last Update 2019-04-15
This project is about using an ESP-32 together with an I2S digital microphone to create an audio sensor.
This could be a decibel meter, or perhaps an environmental noise meter.
The idea is the following:
  • A small box containing a microphone outside your house measures environmental sounds (traffic, etc), for example it takes a 1 second audio recording every 10 seconds
  • A spectral analysis is made of the audio (separating it in different frequency bands), calculating sound intensity
  • Every 5 minutes, the measured sound intensity is sent to a central server on the internet using your home WiFi connection. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
  • The central server takes the measured intensities and can do corrections, like a microphone specific correction, or a correction to apply A-weighting
  • The central server visualises the measurements:
    • We can plot the sound intensities on a map as a coloured dot and get a nice overview how the map changes during the day/week/year
    • We can plot the sound intensities of individual nodes vs time, and get an idea how sound varies from day/night/week/year
Theory
The plan is to divide the audio spectrum up into octaves and calculate the total energy in each octave. To this we can then easily apply sensor/housing specific corrections, do A weighting, etc.
This division of the audio spectrum is chosen so it matches the octaves used in the well-known A-weighting curve.
An octave is basically a factor of two in frequency. Coincidentally an FFT also calculates things in factors of two, for example when sampling at 44100 Hz, you get the following octave boundaries: 22050 Hz, 11025 Hz, 5512 Hz, 2756 Hz, 1378 Hz, 689 Hz, 244 Hz, 172 Hz, 86 Hz, 43 Hz, 22 Hz.
A-weighting
Audio levels are generally measured on a logarithmic scale in dB using "A-weighting". A-weighting calculates a subjective loudness level from a physical loudness, taking into account the spectrum of the audio.
Energy is calculated per octave and a correction factor for that specific octave is applied. The octaves are defined referenced to 1000 Hz, so submultiples like 500, 250, 125, 62 Hz and multiples like 2000, 4000, 8000, 16000 Hz. The correction mains that for each octave, a number is added or subtracted from the raw decibel value.
Links:
  • an ESP32 (or possibly an ESP8266), it has an I2S digital audio input for sampling data from a digital microphone and a WiFi interface to communicate things to the internet
  • a digital I2S microphone, like the INMP441 (datasheet)
Waag society uses the following microphone in their kit 2.1: Invensense ICS4342. I ordered these INMP441 microphones from Aliexpress.
The microphone is connected to the microcontroller as follows:
  • INMP441 GND to ESP32 GND
  • INMP441 VDD to ESP32 3.3V
  • INMP441 SD to ESP32 A4/32
  • INMP441 SCK to ESP32 A16/14
  • INMP441 WS to ESP32 15
  • INMP441 L/R to ESP32 GND
Initial code can be found on github.
What the software should do:
  • Take audio measurement from the microphone at a regular interval (say 1 second every 10 seconds)
  • On the recorded audio, perform a 4096-point FFT with a windowing function (Gaussian for example). This results in 2048 FFT coefficients.
  • Sum up FFT into power per octave, e.g. top 1024 coefficients represent octave of 11025-22050 Hz, next 512 coefficients represent is 5512-11025 Hz octave, etc.
  • Calculate statistics, e.g. minimum/average/maximum as decibels in the current 5 minute interval
  • Every 5 minutes, send the statistics to the network using WiFi
To investigate:
