EspNowSkip
Project EspNowSkip | |
Music skip button based on ESP-Now protocol | |
Contact | bertrik, jelly |
Last Update | 2018-07-03 |
The current ESP-Now skip button prototype needs only about 200 ms after wakeup to send a message and return to deep sleep again.
The plan:
- the skip button itself has been built and works
- create a receiver that consists of an ESP32 (e.g. a SHA badge):
- runs the "revspace-espnow" soft AP and receives ESP Now messages
- connects to the space WiFi and forwards the skip to the music player (and towards MQTT)
Alternatives:
- use two ESP8266, one to receive ESP Now, another one to communicate with the space WiFi: doesn't appear to be necessary when using an ESP32
- use a raspberry pi, orange pi or similar: which one? existing one like projector? adds more dependencies/complications/discussions
- use an ESP32 with wired ethernet: complicates things, needs more hardware, is a separate project by itself
The proposed way of wiring it up, is to make the actual physical button just power up the board. A (super-)cap parallel over the supply wires makes it possible to run the skip program to completion from just a single short press. In case a ESP-Now re-initialisation (which takes a bit more time) is needed, you can just keep the button pressed for a bit longer to complete the initialization process. This way, the SKIP program starts executing as soon as you press the button and there is no quiescent current drain on the battery.
The receiver/master is connected to a raspberry pi or similar, with the EspNowSkip receiving packets from the air and sending them over serial to the raspberry pi. The raspberry pi can then do its magic to make the music skip (e.g. GET/PUT a specific URL of the playback software, send an MQTT message, etc.)
Capacitor calculation
C = I . dT / dV
Battery life
Source code
It contains the following programs:
- skipbutton.ino: an Arduino program that is the button part of the system (slave) which sends the skip message
- skipreceiver.ino: an Arduino program that is the central part of the system (master) which receives the skip message
- skipforwarder.ino: an Arduino program that accepts a skip message over serial from another ESP and forwards it to the squeeze-player and MQTT
- forwardskip.py: a Python script that takes a topic/payload over the serial port from a skipreceiver and forwards it to MQTT
EspNowSkip protocol
It works like this:
- there are two roles:
- a single central "master" node
- one or more "slave" skip-buttons
- when the skip button is pressed, the ESP8266 resets and starts running, reads the last known ESP-Now channel and MAC address from EEPROM and sends the "SKIP" message
- if the skip button doesn't receive an ACK from the central node, it starts a kind of discovery to re-establish the channel and MAC address of the central node
- the discovery procedure tries to find the central node by doing an AP scan, the AP name is the only thing that needs to be agreed upon in advance between master and slave code
- in the list of the APs, the slave node finds the SSID belonging to the central node, then it also knows the wifi channel and MAC address of the central node
- the slave node stores both wifi channel and MAC address in (emulated) EEPROM and goes back to sleep
The data we send is an MQTT-like topic + message, for example
revspace/button/skip now
The master node can simply parse this into two parts (split on the first space) and bridge this to the Revspace MQTT infrastructure.
Skip protocol
Classic HTTP GET
where
Example:
JSON Protocol
To skip, send a HTTP POST to:
http://jukebox.space.revspace.nl:9000/jsonrpc.js
with content
Expect a result like:
References
Future
Done:
make sure ESP8266 ESP-now implementation is interoperable with ESP32 ESP-now implementationindeed it is!
- finalize the ESP32 receiver code, choose between the plain HTTP GET interface and the JSON POST interface.
- update the message sent over ESP-Now, it's currently sends the message: "revspace/button/skip now". The a topic/payload-like protocol looks fine, but perhaps a skip should be announced with payload "revspace/button/skip next" instead. Future upgrades could use "mute", "volume-", "volume+", "shuffle" for the second part of the message, etc.
- add a supercap to the skip button, to allow a short press (e.g. 100 ms) to also be registered -> I have various types in my Samla (e.g. 0.1F 5V).
More distant future:
- use ESP-Now also for other kinds of hacker space infrastructure where low-power consumption is important and/or a power wire is inconvenient: outside temperature for example.
- add more buttons besides just skipping.
- send data back to the skip button, for example we could send a "now playing" message or album art back to a SHA2017 badge and have it shown on its e-ink display.
- use encryption/authentication on the ESP-Now link. I think the protocol already allows this, using a simple shared secret.
