Flipdot
Revision as of 09:25, 18 June 2018 by Bas (talk | contribs)
Project FlipDot
Contact User:Sebastius
Last Update 2018-06-18
Controller
Schema
Serial werkend krijgen
stty -f /dev/ttyUSB0 1200 cstopb cs7 parenb -paroddecho
Code
Met dank aan Juerd:
#!/usr/bin/perl -w
use strict;
use autodie;
open my $fh, ">/dev/ttyUSB0";
my $bla = "regel 1\nregel 2";
my $output = "aA11000\n$bla\n\n\r";
my $xor = 0x7f;
$xor ^= ord for split //, $output;
$output .= chr $xor;
syswrite($fh, $output);
Foto's
