EspNowSkip
Project EspNowSkip | |
Music skip button based on ESP-Now protocol | |
Contact | bertrik, jelly |
Last Update | 2018-05-12 |
The current ESP-Now skip button prototype needs only about 200 ms after wakeup to send a message and return to deep sleep again.
The proposed way of wiring it up, is to make the actual physical button just power up the board. A (super-)cap parallel over the supply wires makes it possible to run the skip program to completion from just a single short press. In case a ESP-Now re-initialisation is need, you can just keep the button pressed for a bit longer to complete the initialization process. This way, the SKIP program starts executing as soon as you press the button and there is no quiescent current drain on the battery.
The receiver/master is connected to a raspberry pi or similar, with the EspNowSkip receiving packets from the air and sending them over serial to the raspberry pi.
Capacitor calculation
C = I . dT / dV
Battery life
The deep sleep current of the Wemos D1 mini has been measured at about 0.16 mA. So in deep-sleep, the battery should last > 10000 hours. Suppose a skip takes 500 ms consuming a current of 150 mA on average. That's about 0.02 mAh per skip, so the battery should last > 10000 skips.
Source code
It contains two Arduino programs:
- skipbutton.ino: this is the button part of the system (slave) which sends the skip message
- skipreceiver.ino: this is the central part of the system (master) which receives the skip message
EspNowSkip protocol
It works like this:
- there are two roles:
- a single central "master" node
- one or more "slave" skip-buttons
- when the skip button is pressed, the ESP8266 resets and starts running, reads the last known ESP-Now channel and MAC address from EEPROM and sends the "SKIP" message
- if the skip button doesn't receive an ACK from the central node, it starts a kind of discovery to re-establish the channel and MAC address of the central node
- the discovery procedure tries to find the central node by doing an AP scan, the AP name is the only thing that needs to be agreed upon in advance between master and slave code
- in the list of the APs, the slave node finds the SSID belonging to the central node, then it also knows the wifi channel and MAC address of the central node
- the slave node stores both wifi channel and MAC address in (emulated) EEPROM and goes back to sleep
The data we send is an MQTT-like topic + message, for example
revspace/button/skip now
The master node can simply parse this into two parts (split on the first space) and bridge this to the Revspace MQTT infrastructure.
References
Future
Future features could be:
- get rid of the old "nrf24l01+" style messaging which used a limited 4-char convention for sending a message (just "SKIP"). We now have 250 bytes to play with, so we could just do a kind of MQTT-over-ESPnow emulation. For example, we could send a MQTT-style topic + content + flags and bridge it to the rest of our space sensor/actuator infrastructure which is completely MQTT-based.
- add more buttons besides just skipping
- send data back to the skip button, for example we could send a "now playing" message or album art back to a SHA2017 badge and have it shown on its e-ink display.
- use ESP-Now also for other kinds of hacker space infrastructure where low-power consumption is important and/or a power wire is inconvenient, e.g. temperature sensor in freezer? What about battery types that can handle sub-zero temperatures?
- make sure ESP8266 ESP-now implementation is interoperable with ESP32 ESP-now implementation
- investigate whether we can make the central node post directly on the mqtt stream via wifi (at the same time as receiving ESP-Now packets), so we don't need the serial connection.
