Pov
what is it
POV is the (virtual) server managing the webcams. It stores video files of all webcams over the last 2 days.
OS specifications
- debian stretch
- 32b
- virtual machine with 2 cores
- 1GB ram
- 10GB root filesystem
- 100GB storage for camera files
software
- motion https://motion-project.github.io/
- used for camera 6 and 11 which are down
- constatus https://vanheusden.com/constatus/
- all other cameras
motion
- motion is installed from the debian repository
- configuration files are under /etc/motion
- main configuration is motion.conf which includes cam*.conf
- as by the design of motion, all its cameras (6 + 11) are monitored from 1 process
constatus
- installed from the github repository https://github.com/flok99/constatus
- installed under /usr/local/constatus
- started (currently, 20170903) from /etc/rc.local
- each camera has its own constatus process - the idea is that if something crashes, that not all cameras will go down
- video archive can be viewed under http://10.42.19.84:port/ where port is 8101 for camera 1, 8102 for camera 2 and so on
The configuration files are JSON files. They consist of 2 or more sections: general, source and then optional sections. Every other section (apart from video loopback) have an array of entries for their data. E.g.
recording specificaions
- 5 FPS video files
- 2 FPS HTTP web interface
cameras
- number, port, protocol of physical dev, where
- CAM 1: 8084, RTSP, hanging above the 3D printer
- CAM 2: 8085, MJPEG, cantine
- CAM 3: 8086, MJPEG, back side of klusruimte
- CAM 4: 8087, MJPEG, front side of klusruimte
- CAM 5: 8088, RTSP, houtbewerkingsruimte
- CAM 6: broken
- CAM 7/8/9/10: 8090/8091/8092/8093, MJPEG, source is Verint Nextiva. these produce an RTP stream which are converted to MJPEG by scripting running on the shell server, see https://github.com/Peetz0r/revcaminfra.
