LoRaGateway
Revision as of 10:59, 10 October 2016 by Bertrik Sikken (talk | contribs) (hoofdletters)
Project LoRaGateway
Een LoRa gateway voor the-things-network
Contact bertrik, User:Dave_o, Maxell
Last Update 2016-10-10
This page is about a LoRa gateway at RevSpace configured for The-Things-Network (TTN), kindly provided by Dave_O.
It's a Kerlink, some essential properties:
  • LoRaWAN EUI: 0000024B080606AC
  • eth0 MAC address: 02:4B:08:06:06:AC
  • Last known IPv4 in the RevSpace LAN: 10.42.45.15
The gateway itself is physically mounted in the ceiling of a disused lavatory on the second floor (with a broken light and a sign that says "Beware of the Leopard", just kidding). It's connected to our discone antenna.
Configuration
Configuration files for TTN in general can be found here:
  • in /mnt/fsuser-1/thethingsnetwork
The gateway is configured for NTP in /etc/ntp.conf to use X.nl.pool.ntp.org where X goes from 0 to 3.
The gateway has been configured for "poly"-packet forwarding. This means it's not just sending data to TTN, but also to the gatewaystats.org website where statistics are kept (number of unique nodes, log of all received packets, etc.)
Status and diagnostics
Online status:
To see what the gateway is communicating with the TTN, run the following on the gateway:
tcpdump -i eth0 -n -vvvX host router.eu.thethings.network
This should show a packet once every 30 seconds with some stats.
You'll also see some JSON packets for each packet received.
