Karaburan
Revision as of 13:25, 5 September 2025 by Bertrik Sikken (talk | contribs) (Sonar sensors)
Project Karaburan
Monitoring water quality
Last Update 2025-09-05
Check:
USB HID as analog input
  • install openocd
 sudo apt install openocd
  • watch the kernel logs
 sudo dmesg -w
Verify that it works:
  • install the evtest package
  • run
influxdb
ROS
Investigation:
  • Use ROS 2, not the old ROS 1
  • Cannot work comfortably with debian, works best with ubuntu
  • Using gpsd:
    • install ros-jazzy-desktop
    • ros2 launch gpsd_client gpsd_client-launch.py
Topics:
  • air quality sensors
    • ammonia
    • NOx
  • water chemical analysis
    • nitrates
    • ammonia
    • dissolved oxygen
    • sulfide/sulfate
    • phosphates?
    • salinity (chlorides?)
  • water physical analysis
    • temperature
    • depth?
  • boat control
    • trajectory -> steering
  • camera control
  • post-processing
    • data presentation
      • video/photo stitching
      • time lapse view
      • map view of properties
  • use cases
    • minimum viable prototype
  • materials
    • boat selection
Investigate RTK GPS
  • stop gpsd.socket
  • run from command line
Validation
  • Relative positioning: with an "fix RTK" solution, place the antenna at 4 points 25cm apart, each point for 20 seconds or so -> you see 4 distinct clusters of points
  • Positioning over short time: put it in a fixed location, make sure that it has "fix RTK" solution, take 100 measurements or so -> determine the radius of the circle that contains 90% of the points
  • Positioning over longer time: do this for (say) an hour
  • Absolute positioning: look up a national reference point, for example "RD-punt 389346", located on the Sluisdijk between Gouda and Moordrecht. Technical data: https://www.nsgi.nl/iv-api/rdinfo/rdpoint/389346
Comparison with reference coordinate
On october 4th 2024, we took the RTK GPS to a kernnet reference point at 51.99712236/4.68886324, results below:
From https://www.nsgi.nl/iv-api/rdinfo/rdpoint/389346:
  • Year 2021: "51 59 49,64004", "4 41 19,90584", 48.039. In decimal degrees that is
  • For dy: 40075km/360 = 111,319 m/deg
  • For dx: dy * cos(latitude) = 68,549 m/deg
Measurements + deviations
Name Latitude Longitude dx (m) dy (m) absolute (m) Remark
Reference 2012 51.99712236 4.68886324 - - 0 by definition
Reference 2021 51.99712223 4.68886273 - - 0 by definition
Screenshot 1 51.99712217 4.68886567 0.167 -0.021 0.168 -
Screenshot 2 51.99712200 4.68886533 0.143 -0.040 0.149 -
Meting 1 51.9971220 4.6888663 0.210 -0.040 0.214 -
Meting 2 51.9971222 4.6888660 0.189 -0.018 0.190 -
Average - - 0.177 -0.030 0.180 -
Air quality sensors
Nitrogen compounds in air
  • NOx: 27.3 ug/m3
  • NO2: 18.6 ug/m3 (9.9 ppb)
Sonar sensors
Investigate this because it allows us to measure depth.
I ordered this one: https://nl.aliexpress.com/item/1005006388343879.html
AliExpress has several types of affordable sonar sensors, focused at detecting fish, but also able to measure depth.
These things seem to come in several flavours:
  • wired
  • wireless, 434 MHz link
  • wireless, bluetooth link (probably serial-over-bluetooth)
  • wireless, wifi?
Which one to get:
  • probably avoid the wired ones, the electronics are in the control box, which is mostly just an unused piece of extra hardware, harder to interface
  • probably avoid the 434 MHz link ones, hard to interface with raspberry pi
  • get wifi? we might like to use wifi for another data link already
  • bluetooth? probably best option, it appears at least one of the protocols is basically just serial-over-bluetooth, should be easy to interface/reverse-engineer
  • get single or dual-frequency unit? single might be cheaper, we don't really care about fish anyway, just depth
Typical inexpensive aliexpress sensor: https://nl.aliexpress.com/item/1005009742685646.html
Water physical analysis
Turbidity / clarity
Boat control
  • 2.4 GHz working frequency
  • 500m range
Interesting links:
remote control
Parts:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
Detect/find pollution source
Implementation
udev handling of serial ports
The udev config file is:
 /etc/udev/rules.d/99-usb-serial.rules
# LIDAR serial converter
SUBSYSTEM=="tty", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", SYMLINK+="ttyLIDAR", MODE="0660", GROUP="dialout"
# quectel GPS
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", SYMLINK+="ttyGPS", MODE="0660", GROUP="dialout"
# ublox GPS
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", SYMLINK+="ttyGPS", MODE="0660", GROUP="dialout"
An USB-nano also appears to have a USB vendor/product id of 1a86/7523 ("USB2.0-Serial") ... same as the quectel GPS?
Same for "AI thinker" USB-serial: vendor/product id of 1a86/7523 (product: "USB2.0-Serial")
To (re)load the properties:
sudo udevadm control --reload-rules
reading temperature sensor
Preparation:
 sudo adduser <name> dialout
Setting up the hardware:
Setting up the software:
  • Install openwire fs
 sudo apt install owfs
 sudo mkdir /mnt/1wire
 server: device = /dev/ttyUSB0
 mountpoint = /mnt/1wire
 allow_other
  • Configure systemd services
 sudo systemctl disable owftpd
  • Start the systemd service
  • Check the logs
 http://localhost:2121 or
 http://raspberrypi.local:2121
