EspWifiTracker
Versie door Bertrik Sikken (overleg | bijdragen) op 6 mrt 2016 om 09:58 (Initial content)
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
Project EspWifiTracker
350px
Location-tracker based on WiFi station ids
Status Initializing
Last Update 2016-03-06
  • track your own bicycle
  • know where your cat goes
  • monitor movement of wild animals for research purposes, like bats or stone martens.
  • the tracker is in deep-sleep most of the time, keeping only a low-power real-time-clock running.
  • every once in a while (say once a day) it wakes up, takes a reading of all WiFi stations in range and their signal strength. It stores these in internal memory.
  • if the tracker wakes up to find an open WiFi station (or one that it knows the WiFi password of), it tries to upload all previous readings to a server.
  • the server resolves the uploaded data into geographical locations using a service like Google or the Mozilla Location Service.
Tracker prototype
I'm working on a prototype of this.
I'm basing this off an inexpensive NodeMCU clone. The NodeMCU is basically an ESP8266-module on a break-out board with an USB-serial converter and a proper 3.3V power supply. The ESP8266 is a WiFi-capable microcontroller, capable of running at 80 MHz and having 1 MB of flash onboard.
To wake up periodically, I'm using a ZS-042 clock module, containing a Maxim DS3231 RTC chip. This module is attached to the NodeMCU through the I2C-bus on pins D1 (SCL) and D2 (SDA).
The NodeMCU can be conveniently programmed from the "Arduino" development environment using the Arduino core for ESP8266 WiFi chip
Other libraries used:
Server backend
Communication between the tracker and the server is always initiated by the tracker. The protocol is REST and the format is JSON. I'm thinking of writing this in Java, with the use of Jackson 2.0 (JSON), Jersey 2.0 (REST) and Jetty libraries.
  • one to upload data from the tracker to the server
  • one to provide configuration data from the server to the tracker
  • a new periodic wake-up schedule
  • list of known WiFi stations + passwords
  • WiFi station whitelist, for stations which are known to be really open to the internet
  • WiFi station blacklist, for stations which are open (unencrypted), but not really open to the internet
Challenges
Some things to solve yet:
  • first of all make a working prototype
  • using "WiFi hotspots": bypass so-called captive portals. Many open web services spoof DNS after connecting to the access point and re-direct you to a webpage where you either need to log in or click some 'I agree' button. It's easy for a human to understand this, possibly not so easy for an embedded device.
  • make it lower power: so we can use a smaller battery or get longer tracking time
  • make it smaller and lighter: so it can be attached to smaller items (e.g. a migrating bat)
