ZX81PLUS35 ZX81 clone
As for now comments and questions on the design can be made here [2] (raspberry PI forum off topic section)  :-)
Introduction to the ZX81+34
The ZX81+34 is a much improved ZX81 that people can build themselves.
The ZX81+34 should be fully compatible with the original ZX81, but with the following improvements over the original ZX81 :
  4. Supports ZX81 BASIC in either a EEPROM or in an OTP (one time programmable ROM)
  9. Can drive a simple LCD display, and some external I/O for "stand alone" applications like driving tiny robots. Debug LED/Backlight LED support.
Current Status
At the moment the PCB of the first prototype has been designed, and is ready to be tested.
26/01/2015 2 PCB's are being made, waiting for delivery next week, also a component order list has been created. 27/01/2015 A component placement diagram has been made, and has been published here.
3D Preview of early ZX81+34
The botom picture also shows the four chips of the original ZX81, and what replaces them on the ZX81+34, green is the Z80 CPU, RED the (EE)PROM, Yellow the RAM (1K on the ZX81, 16/32K on the ZX81+34). Blue indicates the logic of the ULA, contained in a single 40-Pin IC on a ZX81, the ZX81+34 replicates it with 24 conventional but modern logic ICs.
Schematic 81+34
The latest schematic (.PDF) can be found here: File:ZX81+34 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: File:ZX81+34 kleur rev 1.0.pdf.
The Bill of Material (BOM) for the ZX81+34 can be found here File:Z81+34 BOM.ods
Layout ZX81+34
Keyboard for ZX81+34
File:Nieuw keyboard ZX14.pdf
Alternative font for ZX81+34
I also designed an alternative (fun) font for the zx81+34 that can replace the one in ROM, it should be compatible with existing software, so graphic symbols are unchanged. As inverted characters are a hardware function, inverted characers (and graphics) are simply inverted copies of the original characters. Here is a preview.
Here is the original to compare it with.
The final ZX81+34
Finally mid January 2015 the PCB of the ZX81+34 was finished, a mounting hole was added (needed to mount in an enclosure). The picture below is a 3D rendered preview, some of the texts on the preview are there to comment some of the functions, and will not be present on the silkscreen of the final PCB.
Here is a drawing to help assembling the right components at the right places (A placement drawing), it was made from the real silkscreen gerber-file (in red)comments and component values in black.
Starting the assembly
