LichtKrant
Revision as of 14:46, 12 November 2025 by Bertrik Sikken (talk | contribs) (UDP RGB565 interface)
Project LichtKrant
Controller for 3-colour 80x7 pixel moving LED sign
Last Update 2025-11-12
Features
  • Reverse engineered it, I know how it works and documented it, the original controller board has been removed and replaced by an ESP8266.
  • The sign can show 4-bit gradients in both red and green, blue is ignored.
  • Arbitrary bitmap graphics can be sent to the display over WiFi, using an UDP protocol encoding one frame in one packet as 80x8 pixels in rgb565 format.
Physical dimensions:
  • 80 pixels in about 613 mm wide
  • case is about 675 mm x 109 mm
  • there are two screw holes on the sides, about 660mm apart
  • screw holes are size M6
Reverse engineering
lichtkrantconnector
Processor board
It takes 5V as input.
The PCB has the following text on it: HXITC017_2.PCB
LED board
How does it work
*  J1.1: IC2.A1 -> IC2.B1 -> via ... -> SRCLK signal of both column shift registers
*  J1.2: GND
*  J1.3: IC2.A2 -> IC2.B2 -> via ... -> RCLK signal of both colomn shift registers
*  J1.4: GND
*  J1.5: IC1.B3 -> IC1.A3 -> U11.SER -> data pin for upper shift register (green)
*  J1.6: GND
*  J1.7: IC1.B4 -> IC1.A4 -> U1.SER ->  data pin for lower shift register (red)
*  J1.8: GND
*  J1.9: IC2.A7 -> IC2.B7 -> via ... -> row enable
* J1.10: VCC
* J1.11: IC2.A3 (row) -> IC3.A ->       row select
* J1.12: VCC
* J1.13: IC2.A4 (row) -> IC3.B ->       row select
* J1.14: VCC
* J1.15: IC2.A5 (row) -> IC3.C ->       row select
* J1.16: J4 (IR receiver)
* J1.17: IC2.A6 -> IC2.B6 -> IC3.G2A -> frame enable, appears to have a pull-up already, so can be left unconnected
* J1.18: ???
* J1.19: ???
  • columns
  • rows
  • other
    • 5V signals
    • GND signals
Levels on the bus are 5V.
Theory of operation:
  • next row
Timing
Columns:
Power consumption
It appears that J1.17 is used by the original control board to set the global brightness.
  • all LEDs off, about 0.1 A (ESP8266 only?)
  • all red LEDs on, about 3.9 A
  • all green LEDs on, about 3.6 A
  • all LEDs (red + green) on, about 5.8 A
  • some text in red on the display, about 1.5A
Hardware modifications
Wemos D1 mini as sign controller
Modifications:
  • Remove the original controller board
  • Solder a power connector on the center of the display PCB, on the footprint that was already present. This is now the main entrance for 5V power.
  • Add a Wemos D1 mini board and connect it to the J1 connector of the display board, it is powered with 5V from the J1 connector, pinout:
Connections
J1 connector Wemos D1 mini Remark
J1.1 D8 Column data shift
J1.3 D7 Column data latch
J1.5 D6 Green data
J1.7 D5 Red data
J1.8 G Ground
J1.9 D4 Row enable
J1.10 5V 5V from LED board to Wemos D1 mini
J1.11 D3 Row select bit 0
J1.13 D2 Row select bit 1
J1.15 D1 Row select bit 2
 sudo apt install python3-pip
 sudo pip3 install platformio
Driving the pixels
Variable pixel brightness
Variable pixel brightness is implemented using temporal dithering that flashes the pixels on/off:
  • At each frame start, for each pixel, we add the brightness value from the frame buffer to the brightness count (e.g. 0-255). If the addition results in an overflow, the pixel is turned on, otherwise it is turned off. For example, adding a brightness value of 128 causes the addition to overflow every other time, causing a 50%/50% duty cycle at half the frame frequency.
  • The above is implemented for the red and green sub-pixels separately.
Frames of 80x8 pixels in RGB565 format (big endian) can be sent over UDP to port 1565. The blue (B) channel is ignored, as is the lowest line of the frame.
The frames can be converted from raw RGB to the RGB565 format using the ledbanner2udp program.
 convert -size 80x10 -crop 80x8+0+2 -font 8-BIT\ WONDER.TTF -pointsize 9 -fill red -background black caption:"AweSome" -depth 8 rgb:- |./ledbanner2udp
 convert metaballs.gif rgb:- |./ledbanner2udp
The software attempts to join multicast group 239.0.0.1 at port 1565 to receive UDP frames. If that fails, it opens a regular UDP unicast receive socket on port 1565 to receive UDP frames.
The software contains an mDNS responder that allows the network interface to be addressed as esp-ledsign.local (instead of using the ipv4 address). At startup, when no UDP frames have received yet, the display shows its IP address.
Command interpreter
Integration into revspace infrastructure
Lichtkrant in the kitchen
Frame forwarder
A C program (https://github.com/bertrik/lichtkrant/blob/master/ledbanner2udp.c ledbanner2udp]) accepts frames in the ledbanner internal frame format, converts the pixels to rgb565 (to make one frame fit in exactly one UDP packet) and forwards the frame to a configurable UDP host/port (ip address of the lichtkrant).
The UDP destination port also supports a multicast address. When sending to a multicast address, the TTL is configured to 1 (local network). For multicast, the ledbanner script is configured for 239.0.0.1, port 1565.
This program runs on the ledbanner pi, chained at the end of the 'pipeline' of image processes.
An UDP frame is organised in 8 rows (top to bottom) of 80 pixels each (left to right) of 16-bit words. Each 16-bit word is constructed like this (big endian):
  • bits 15-11: red
  • bits 10-5: green
  • bits 4-0: blue
This results in one UDP packet of 1280 bytes per image frame, which fits within the typical UDP frame size (max 1500 bytes).
Possibly useful other info:
