WaterBuffaloVuvuzela
Versie door Oops (overleg | bijdragen) op 27 jul 2025 om 19:48
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
Project Water Buffalo Vuvuzela
Making an awful noise
Contact Oops
Last Update 2025-07-27
We bought a water buffalo horn and made it into a ornament which makes a very loud noise.
Resources
We bought a water buffalo horn from Nature Deco.
After a while of carrying it around and it being big and heavy and pointy, we decided to make it into something that makes noise.
Process
If you shine a bright flashlight into the horn in a dark room it lights up and you can get a sense of how far down the horn it is hollow.
End-on view of a water buffalo horn
Water buffalo horn before it was cut
We used a hand crosscut saw to cut off the tip of the horn. It was still solid where we cut it.
So we cut it again a bit further down, and ended up with a hole. The remaining rim was too thick to easily make a buzzing noise against.
Tip and a section cut from the water buffalo horn, and a mouthpiece glued into the resulting hole.
Off-cuts from making the water buffalo Vuvuzela
Luckily I have been making mouthpieces for my French Horn and had some spare early test runs.
We jammed one into place and it makes a very loud noise.
We used hot glue to fix the mouthpiece in place and we now have something which functions as a Vuvuzela.
Reviews
Paraphrase of discussion which occurred in our next-door neighbour's house:
Q
Why does [the young neighbour] play that horn at eight o'clock in the morning?
A
Because they've been told they're not allowed to make that noise before eight o'clock.
