USB-B2C converter
Versie door Wouterdd (overleg | bijdragen) op 29 jun 2025 om 11:36 (Created page with "{{Project |Name=USB-B naar USB-C inbouw converterbordje |Picture=USB-B2C-bordje.jpg |Omschrijving=A small PCB converter board with USB type-B footprint, featuring a USB type-C port and 2 5k1 resistors for direct conversion |Status=Completed |Contact=wouterdd }} I got tired of using my audio interface with a USB type-B port, so I decided to create a small drop-in replacement PCB that uses the USB type-B pins but features a USB type-C port. To replace your type-B por...")
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
Project USB-B naar USB-C inbouw converterbordje
Contact wouterdd
Last Update 2025-06-29
I got tired of using my audio interface with a USB type-B port, so I decided to create a small drop-in replacement PCB that uses the USB type-B pins but features a USB type-C port. To replace your type-B port, desolder it and grab 2x 2 pin 2.54mm headers. Since the pins on a USB type-B board are 2.5(4?)mm x 2.00mm, you'll have to file away the sides of these headers to fit.
