WwHomeCDU
Project Winwing HomeCDU | |
Multipurpose Home Computer Display Unit (smarthome et al.) on basis of Winwing MCDU/PFP3N | |
Contact | Fabo |
Last Update | 2025-05-15 |
Intro
The Winwing CDU series is a range of affordable flight simulator peripherials based on flight management computer interfaces in modern(ish) airliners. The MCDU is based on a Thales MCDU used in Airbus aircraft (A320 family), while the PFN 3N is based on a Smiths Industries unit used in Boeing 737NGs.
That translates to a small but readable display, which can display 336 characters over 14 lines (24 chars each), a full alphanumeric keyboard with a smattering of special characters, some page selection buttons which are not relevant to the project, and 6 Line Select keys on each side of the display, which are used normally to interact with options displayed on screen.
The device connects to a PC over a USB-C cable, and presents as USB HID device, by default a game controller on Windows.
Goals of the project
Overal goals
My eventual goal is to be able to use either/both these devices as hubs for all manner of (smart)home stuff. Being mounted at a convenient place (or places) in the house to use for tasks like
- displaying information from various sensors available, such as temperature, humidity, state of windows/doors, etc.
- timers for cooking and similar
- daily reminders for things like medication, planned events
- smart home control via Home Assistant and downstream devices e.g. zigbee lights
- maybe recipe following?
Initial goals
- estabilish connection from a windows PC to the device that allows to write to the display ✓
- write software that will allow easy generation of payloads to the device
- integrate available driver directly with this piece of software
- re-write driver from scratch or find a free alternative
Hardware integration
The eventual goal is to drive the device(s) from a RaspberryPi. This will necessitate integrating the hardware with whatever version of (most likely) Linux will run on the Pi. It seems that there are already available some Python drivers for Winwing devices built on top of PyUSB so platform-agnostic development should be OK.
Software integration
There is one relatively large decision to be made here. I have a home server. Do I consider the device with a pi as a thin client and run the logic on the home server, or do I run the logic on the Pi itself? The obvious advantage is that it's self-contained and can work independently. The disadvantage is in the maintenance, and, perhaps, performance (though I doubt that). I will need to also have a think about designing the software to run. I definitely know already I want it to be modular.
Mounting
At some point, I will have to design a mount for the device, ideally such that will allow the Raspberry Pi to exist in the mount permanently, while the Winwing CDU can be easily detached.
Latest progress
Current state of being
I have received the MCDU on May 13th, and started messing with it the next day.
What I have initially found, is that MobiFlight, an open-source platform for hardware controls integration with flight simulation software, already has support for Winwing CDU in beta. Unfortunately, while the platform itself is open-source, it seems that it is using a closed-source driver to drive the device (hence the goals to first integrate the existing closed driver and then replace it). At least figuring out how to interface with the driver will be easy.
For starters, I have used Postman to make a connection to websocket interface that MobiFlight is exposing to outside world to drive the display.
Unfortunately the format used for this is... not great. A JSON array of 336 arrays, each of them corresponding to a single character, each character being either empty, or having 3 elements - character to be displayed, color, size (small or large). Hence, the need to have something more user-friendly to generate payloads for testing.
Current next steps
I have two things to do next:
- Aforementioned human friendly interface to generate payloads
- Figure out what to do with buttons and LEDs.
Past state of being
Not yet
