Treinonderdelen/ICMm/Bestemmingsaanduiding
Revision as of 09:28, 2 April 2025 by Shiz (talk | contribs) (Created page with "thumb|350px Het LED-display aan de buitenkant dat aangeeft waar de trein naartoe gaat. = Hardware = Grotendeels gebaseerd op dezelfde hardware als het SGMm-display, maar véél beter in elkaar gezet. * CPU: Hitachi HD6413003 @ 16MHz ** Package: QFP112 ** Architecture: [https://en.wikipedia.org/wiki/H8_Family H8/3003] ** [https://www.renesas.com/us/en/products/microcontrollers-microprocessors/ot...")
  • CPU: Hitachi HD6413003 @ 16MHz
  • FPGA: Xilinx Spartan XCS30XL-TQG144AKP
    • Package: TQFP144
    • Architecture: Spartan XL
    • Datasheet
  • Flash:
    • Atmel AT29C010A, label: "340141 V.1.01"
      • Package: PLCC32
      • Vermoedelijk hetzelfde als bij het SGMm-display, zie die pagina voor dump
    • Atmel AT29C010A, label: "340142 V.1.01"
      • Package: PLCC32
  • Serial buffer: TL16C550CIFN
Resolutie: 160 x 32
Connectors
Één Harting Han 24DD-connector aan de bovenkant van het display, met de volgende pinout:
   _/-----------\_
 _/  21  - 23  -  \_
/    17  - 19  -    \
|    13  -  -  -    |
|     9  -  -  -    |
\_    -  -  -  -   _/
  \_  1  2  -  - _/
 1: power Vcc
 2: power GND
 3: N/C                             [no pin]
 4: N/C                             [no pin]
 5: N/C                             [no pin]
 6: N/C                             [no pin]
 7: N/C                             [no pin]
 8: N/C                             [no pin]
 9: address bit (0?)
10: address bit (1?)                [no pin]
11: address bit (2?)                [no pin]
12: address bit (3?)                [no pin]
13: RS-485 GND
14: RS-485 GND (for address bit 2?) [no pin?]
15: RS-485 GND (for address bit 1?) [no pin?]
16: RS-485 GND (for address bit 0?) [no pin?]
17: RS-485 in-
18: RS-485 in-                      [no pin]
19: RS-485 out-
20: (debug RX?)                     [no pin]
21: RS-485 in+
22: RS-485 in+                      [no pin]
23: RS-485 out+
24: (debug TX?)                     [no pin]
Één interne JST-connector van de hoofdconnector naar het logica-bord, niet nodig voor externe verbinding:
Pin  1: RS-485 IN+       [external: pins 21 and 22]
Pin  2: RS-485 IN-       [external: pins 17 and 18]
Pin  3: signal GND       [external: pins 13-16]
Pin  4: (debug RX?)      [external: pin 20]
Pin  5: (debug TX?)      [external: pin 24]
Pin  6: signal GND       [external: pins 13-16]
Pin  7: address bit (0?) [external: pin 12]
Pin  8: address bit (1?) [external: pin 11]
Pin  9: address bit (2?) [external: pin 10]
Pin 10: address bit (3?) [external: pin 9]
