Spacenet/FreeRADIUS configuration
Revision as of 09:56, 7 April 2024 by Shiz (talk | contribs) (Add note about debugging to README)
The below configuration is used for SpaceNet at RevSpace, written for and tested with FreeRADIUS 3.2.1. The paths are relative to the base configuration directory, e.g. /etc/freeradius/3.0.
README
FreeRADIUS config - RevSpace edition
Operating principle:
  We are federated with SpaceFED (https://spacefed.net/) to provide the 'spacenet' network.
  Our participants can authenticate at any spacenet-compatible access point with their RevSpace LDAP credentials,
  and participants from other hackerspaces can authenticate through their own hackerspace via our access points.
  Usernames are formatted like <username>@<hackerspace.nl>, and the domain part is used to proxy the authentication
  to the correct remote RADIUS server through SpaceFED.
  In order to prevent credential sniffing by the local RADIUS server,
  a tunnel from the client to the remote RADIUS server is setup by means of EAP-TTLS or PEAP,
  and an anonymous outer identity (usually anonymous@<domain>) is used instead to route the request.
  We have three scenarios:
  - RevSpace participant authenticates at RevSpace spacenet:
    User -(802.1X)----------------> Local client (access point)
         -(RADIUS: lan.conf)------> Local server (outer.conf)
         -(EAP-TTLS or PEAP)------> Local server (inner.revspace.conf)
         -(PAP or EAP-GTC)--------> LDAP
  - RevSpace participant authenticates at other location:
    User -(802.1X)----------------> External client (access point)
         -(RADIUS)----------------> External server
         -(RADIUS: spacefed.conf)-> Local server (outer.conf)
  - Spacenet participant authenticates at RevSpace spacenet:
         -(RADIUS: spacefed.conf)-> External server
         -(EAP-TTLS or PEAP)------> External server
Authentication:
  While we could skip EAP-TTLS or PEAP for local-local authentication, this would make user configuration
  inconsistent between being at RevSpace and at other hackerspaces, defeating the point.
  Thus, we *always* use EAP-TTLS or PEAP as the outer authentication layer.
  Since we do not store LDAP passwords in plain text or a weak hash,
  we need to receive the plaintext password inside the encrypted TLS tunnel to compare it.
  This limits us to one of the following plaintext password mechanisms as the inner layer:
  - PAP
  - EAP-GTC
Configuration structure:
  - radiusd.conf            # main configuration file, generic settings and includes everything
  - modules.d/              # configuration for FreeRADIUS modules
    - realms.conf           #   ! realm /format/ configuration (user@realm)
    - eap.revspace.conf     #   ! EAP configuration (TLS certificates, mechanisms, ...)
    - ldap.revspace.conf    #   ! LDAP configuration (server, RADIUS server DN and password, filters, ...)
  - clients.d/              # configuration for RADIUS clients (entities like access points that talk to us to authenticate a user)
  - realms.d/               # configuration for RADIUS realms (the domain part, to figure out where to route authentication request)
    - default.conf          #   'must-define' realms LOCAL and NULL
    - revspace.conf         #   realms we handle, mostly empty configuration blocks to imply local processing
    - spacefed.conf         #   fallback realm, with instructions to proxy to SpaceFED
  - servers.d/              # configuration for RADIUS servers (that listen on ports and process authentication requests)
    - outer.conf            #   outer unencrypted tunnel, to determine where the request should be proxied towards
    - inner.revspace.conf   #   inner encrypted tunnel, for authenticating RevSpace participants
Debugging:
  As we use TLS, the usual recommended way to run FreeRADIUS in debug mode (`freeradius -X`) will not work.
  TLS on FreeRADIUS requires threads, and `-X` is a shorthand for `-sfxx -l stdout`; `-s` disables threading.
  Instead, use `-fxx -l stdout` when debugging.
radiusd.conf
# Paths
prefix = /usr
exec_prefix = /usr
sysconfdir = /etc
localstatedir = /var
runstatedir = /run
sbindir = ${exec_prefix}/sbin
logdir = ${localstatedir}/log/freeradius
libdir = ${exec_prefix}/lib/freeradius
raddbdir = ${sysconfdir}/freeradius/3.0
radacctdir = ${logdir}/radacct
name = freeradius
confdir = ${raddbdir}
modconfdir = ${confdir}/modules.d
certdir = ${confdir}/pki
cadir   = ${confdir}/pki
run_dir = ${runstatedir}/${name}
db_dir = ${raddbdir}
checkrad = ${sbindir}/checkrad
# Server
pidfile = ${run_dir}/${name}.pid
security {
	user = freerad
	group = freerad
	allow_core_dumps = no
	max_attributes = 200
	# reject immediately (no security delay)
	reject_delay = 0
	# respond to server status requests
	status_server = yes
thread pool {
	start_servers = 5
	max_servers = 32
	min_spare_servers = 3
	max_spare_servers = 10
	# unlimited power... err, requests
	max_requests_per_server = 0
	auto_limit_acct = no
tls {
	certificate_file = "${certdir}/server.pem"
	private_key_file = "${certdir}/server.key"
	tls_min_version = "1.0"
	tls_max_version = "1.3"
	cipher_list = "DEFAULT@SECLEVEL=0"
	random_file = "/dev/urandom"
# Requests
max_request_time = 30
cleanup_delay = 5
max_requests = 16384
hostname_lookups = no
# SPACENET: required!
proxy_requests = yes
# Logging
log {
	destination = stderr
	colourise = yes
	# don't log secrets, even in debug mode
	suppress_secrets = yes
	## please set the fields below to 'no'
	## when not debugging!
	# log authentication
	stripped_names = yes
	auth = no
	auth_accept = no
	auth_reject = no
	# log password attempts
	auth_badpass = no
	auth_goodpass = no
	## debug configuration for above
	#auth = yes
	#stripped_names = no
	#auth_accept = yes
	#auth_reject = yes
	#auth_badpass = yes
	#auth_goodpass = no
# Modules
modules {
	$INCLUDE modules.d/
# Policy
policy {
	$INCLUDE policy.d/
# Clients
$INCLUDE clients.d/
# Realms
$INCLUDE realms.d/
# Servers
$INCLUDE servers.d/
modules.d/
eap.revspace.conf
eap eap.outer {
	default_eap_type = ttls
	timer_expire = 60
	tls-config tls-config {
		certificate_file = ${tls.certificate_file}
		private_key_file = ${tls.private_key_file}
		tls_min_version = ${tls.tls_min_version}
		tls_max_version = ${tls.tls_max_version}
		cipher_list = ${tls.cipher_list}
		random_file = ${tls.random_file}
	ttls {
		tls = tls-config
		virtual_server = server.inner-revspace
		default_eap_type = "gtc"
	peap {
		tls = tls-config
		inner_eap_module = eap.inner-revspace
eap eap.inner-revspace {
	timer_expire = 60
	gtc {
		auth_type = "PAP"
ldap.revspace.conf
ldap ldap.revspace {
	server = "ldaps://ldap2.space.revspace.nl"
	identity = "cn=freeradius,ou=services,dc=space,dc=revspace,dc=nl"
	password = "<EXPUNGED>"
	base_dn = "dc=space,dc=revspace,dc=nl"
	user_dn = "RevSpace-LDAP-UserDn"
	tls {
		ca_path = "/etc/ssl/certs"
	user {
		base_dn = "ou=people,dc=space,dc=revspace,dc=nl"
		scope = "one"
		filter = "(uid=%{%{Stripped-User-Name}:-%{User-Name}})"
	group {
		base_dn = "ou=groups,dc=space,dc=revspace,dc=nl"
		scope = "one"
		filter = ""
		membership_filter = "(member=%{control:${..user_dn}})"
	options {
		dereference = "always"
	update {
		control:Password-With-Header += 'userPassword'
	post-auth {
		update {}
	accounting {}
realm.conf
# realm formats
#  'user@realm'
realm realm.email {
	format = suffix
	delimiter = "@"
	ignore_null = yes
#  'realm\user'
realm realm.ntdomain {
	format = prefix
	delimiter = "\\"
	ignore_null = yes
realms.d/
default.conf
# these entries are needed, but we don't do anything with them
realm LOCAL {
realm NULL {
revspace.conf
realm revspace.nl {
	# nothing here implies local handling
spacefed.conf
home_server nlnode1.spacefed.net {
	type = auth+acct
	ipv6addr = <REDACTED>
	port = 1812
	secret = "<EXPUNGED>"
	require_message_authenticator = yes
	response_window = 5
	zombie_period = 60
	revive_interval = 120
	status_check = status-server
	check_interval = 30
	num_answers_to_alive = 3
	coa {
		# initial retransmit interval (1..5)
		irt = 2
		# maximum retransmit timeout (1..30, 0 == no maximum)
		mrt = 16
		# maximum retransmit count (1..20, 0 == retransmit forever)
		mrc = 5
		# maximum retransmit duration (5..60)
		mrd = 30
home_server_pool spacefed-pool {
	type = "client-balance"
	home_server = nlnode1.spacefed.net
realm DEFAULT {
	nostrip
	auth_pool = spacefed-pool
clients.d/
localhost.conf
# for debugging
client localhost {
	shortname = "localhost"
	ipaddr    = 127.0.0.1
	require_message_authenticator = no
	nas_type  = "other"
lan.conf
# Ethernet
client lan.poeswitch {
	ipaddr          = 10.42.42.12
	shortname       = "poeswitch"
# Wi-Fi
client lan.foundrymc1000 {
	ipaddr          = 10.42.62.1
	shortname       = "foundrymc1000"
client lan.aruba {
	ipaddr          = 10.42.62.3
	shortname       = "aruba radius proxy ip"
spacefed.conf
client spacefed.nlnode1v6 {
	ipaddr          = <REDACTED>
	shortname       = nlnode1v6
servers.d/
outer.conf
# outer unencrypted server for PEAP/TTLS
server default {
	# radius (1812)
	listen {
		type = auth
		ipaddr = *
		port = 0  # use /etc/services
		virtual_server = "default"
	# radius-acct (1813)
	listen {
		type = acct
		ipaddr = *
	# radsec (2083)
	listen {
		type = auth+acct
		ipaddr = *
		port = 2083
		proto = tcp
		tls = ${tls}
	# auth flow: start
	authorize {
		preprocess
		# this statement decides where the request should be proxied to,
		# through the `pre-proxy` & `post-proxy` flows, or if it should
		# be processed locally through the `authenticate` flow.
		realm.email
		if (!&Realm) {
			update reply {
				Reply-Message := "Please specify a realm to authenticate with."
			reject
		eap.outer
	# auth flow: process local
	authenticate {
		eap.outer
	# auth flow: process remote
	pre-proxy {
		# uncomment when we upgrade to FreeRADIUS 3.2.3/3.3+
		#eap.outer
	post-proxy {
		eap.outer
	# auth flow: end
	post-auth {
		eap.outer
	# acct flow: start
	preacct {
		preprocess
		acct_unique
		realm.email
	# acct flow: local
	accounting {
		attr_filter.accounting_response
inner.revspace.conf
# inner encrypted server for EAP-TTLS/PEAP
server server.inner-revspace {
	# for debug purposes
	#listen {
	#	ipaddr = 127.0.0.1
	#	port = 18120
	#	type = auth
	# auth flow: start
	authorize {
		# split and lookup user and password
		realm.email
		if (Realm != "revspace.nl") {
			reject
		ldap.revspace
		# authentication methods
		eap.inner-revspace
		pap
	authenticate {
		# lookup user and password
		ldap.revspace
		eap.inner-revspace
		Auth-Type PAP {
			pap
	# auth flow: end
	post-auth {
		Post-Auth-Type REJECT {
			attr_filter.access_reject
		ldap.revspace
		eap.inner-revspace
