GridFrequency
| Last Update | 2023-07-30 |
I've tried a couple of algorithms, and the 'phasing' algorithm seems to be superior. Using this algorithm on an ESP32c3 board the frequency can be determined accurately. No mains interfacing hardware is required, measurement data can be easily transferred using MQTT over a WiFi network.
Concept
Desired end result:
Phasing algorithm
The algorithm is as follows:
- Sample the mains frequency waveform continuously at about 5000 Hz
- Correlate during 1 second with a perfect 50 Hz reference waveform, by keeping a sum of the waveform multiplied by a cosine (I) and a sum of the waveform multiplied by a sine (Q)
- After one second, calculate the phase using, atan2(Q, I). Changes in the phase compared to the previous second represent the deviation / time shift from the perfect 50 Hz frequency.
This results in:
- continuous process, with a new frequency value every second
- the algorithm uses *all* of the data contained in one second (there is no single threshold value), thus producing a robust value
- any DC offset in the mains frequency waveform is automatically balanced out, no need to keep track of the median or quartile values
Zero cross algoritm
This is my older idea for an algorithm to get accurate instantaneous frequency:
Visualisation
- just show the relative phase angle on the LED ring, this could be a single bright pixel for the latest phase measurement and progressively dimmer pixels for older phase measurements.
Mains waveform ring
Concepts:
Calculation:
| GND | GND | Ground |
| VCC | 5V | Powers the ZMPT101B from the wemos D1 mini |
| OUT | A0 | Analog mains waveform, 0..5V, 180 kohm resistor in series |
Luatos ESP32C3
This module (with serial chip) seems to work quite well so far:
- Senses mains waveform under some circumstances even without a wire attached, using the 'phase' software algorithm
The ADC1/UART1 RX pin is the input for 50 Hz. You can just leave that unconnected and it will pick up 50 Hz, or perhaps connect a short piece (20 cm or so) of wire to it.
To flash the esp32c3 board:
- install platformio
- check out the code
git clone https://github.com/bertrik/MainsFrequency
- enter the esp32c3phase directory
cd MainsFrequency cd esp32c3phase
- connect the board, compile and upload
- connect with serial terminal, to watch frequency measurements
pio device monitor
